Old 03-29-2009, 09:46 AM   #1
silaypalmer13
Drives: 2009 Toyota Yaris Sedan
NEW TRANSMISSION PROBLEMS HELP!
Hey everyone, I've had my yaris for about 1 month now, its got about 900 miles, with an auto tranny. Now, whenever we start the car up, it has the "cool" light on usually for a couple of minutes. Its still in the 30's here durring the day too.Heres the problem.
When I leave my house, I instantly have to get on a highway, about 60mph. The transmission will NOT shift from 3rd to 4th until a little while after that light goes out. So i've been driving at about 45 until that happens, as it revs high and is at about 3500 rpm when i do the speed limit. Is this normal??? It seems like that could damage the engine if I was next to a freeway thats 70mph. THanks
silaypalmer13 is offline   Reply With Quote
Old 03-29-2009, 09:49 AM   #2
detroiter
detroiter's Avatar
It's normal. It's part of the Yari's warm up process. I'd say if your going to get on the freeway right away, just let the car warm up a tad bit longer then just hopping on and gunning it. Have fun driving :)
Old 03-29-2009, 09:53 AM   #3
silaypalmer13
That just seems really weird that you would have to wait. I'm guessing thats pretty hard on the engine if you drive it right away while its still in 3rd right?
Old 03-29-2009, 10:02 AM   #4
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
That's normal, and the same with my daughter's Echo automatic. The engine/tranny has to get to a certain temperature before it will go into 4th.
mark schofield is offline   Reply With Quote
Old 03-29-2009, 10:18 AM   #5
yes, even when the cool light goes off, the engine is not yet at full operating temperature, this is normal...
Old 03-29-2009, 12:53 PM   #6
Ryu
Running cold engine (with cool light on) on highway speed might not be a good idea, so I would suggest take 1-2min to warm up your car in your case since you have to take highway right away.
Old 03-29-2009, 01:05 PM   #7
supmet
Drives: 2007 4 Door Yaris
God is telling you to move somewhere warmer??
Old 03-29-2009, 01:31 PM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The engine cool light will go out at 130 deg F. The engine isn't warmed up till 180 deg F. Until the engine is warmed the transmission will not upshift to fourth. Some say the ECU is separate from the transmission, but I guess not.
Old 03-29-2009, 02:43 PM   #9
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
ALL toyota's i believe are like that.my 91 celica does the same thing except it won't shift out of second ..
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 04:01 PM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Transmission needs to warm up????? bojim General Yaris / Vitz Discussion 9 01-01-2007 05:49 PM
