Old 04-02-2009, 01:24 AM   #1
mauiyaris
Drives: 09 yaris
1.5 an oil burner?
I was browsing through the owners manual and found that Toyota considers a motor that burns 1qt of oil every 600 miles acceptable. This seems absolutely outrageous to me. Does the Yaris burn oil?
thanks
mauiyaris is offline   Reply With Quote
Old 04-02-2009, 02:48 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
No.
Old 04-02-2009, 02:52 AM   #3
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Originally Posted by yaris-me View Post
No.
+1
aca72 is offline   Reply With Quote
Old 04-02-2009, 08:17 AM   #4
1stToyota
1stToyota's Avatar
5K OCI's and oil level has never moved off of full between oil changes.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-02-2009, 12:14 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
33,000 kilometers now and haven't seen it move down the stick one bit between changes.
Old 04-02-2009, 01:22 PM   #6
if it burnt 1qt every 600miles.. i don't think it would even pass emission test...
Old 04-02-2009, 04:10 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
But you occasionally see a new car of any brand that guzzles oil. Perhaps rings installed upside down or some such. Makers cover themselves by saying it's normal.
I remember the '54 Chevy we had when I was a little kid. Pop said it guzzled oil at a prodigious rate when new. He said it coincided with Chevy's introduction of the then-new chrome piston rings. Dealer repeatedly said it was normal. Finally it broke in after thousands of miles of driving, and never needed added oil between changes. Rings were just very slow to seat in that case. Similar things still occur sometimes.
Old 04-02-2009, 04:56 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
I think they meant 6000 miles. If you drove your car like a grandma since it was bought then probally piston rings didnt seat properly and yes you may burn a tad bit of oil. Which will progressively get worse as the years go on. Especially if you are not maintaining your car regularly. If you broke in your engine properly and changing oil reguarly it will be awile before you have oil burning issues. Unless you are loosing oil to point where you are atleast a quart low before its time to change the oil again then you have a problem. If you are loosing even a quarter or half a quart in 3k miles. By then you are doing a oil change and your back up to full again so no biggie.
Old 04-03-2009, 09:55 PM   #9
Yaris Hilton
Smile
I expect they did mean 600 miles. That's a typical position for a car company presented with an excessive oil consumption claim. (It's really not normal, of course.)
The recommended oil change interval is 5000 miles.
FWIW, I just checked the oil on my new one at a bit over 1100 miles. Not only has the level not gone down, the oil's still so clear it's very difficult to see on the dipstick.
Old 04-03-2009, 10:07 PM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Ive never had any abnormal oil levels to indicate burning in 60k miles worth of changes.
Old 04-04-2009, 12:37 AM   #11
firebob
Drives: 09 yaris
I did have a few days where mine drank the oil. It was between the 25,000 and 30,000 mile checkups. I’m using Mobil One 5w-25 (mixing 5-20 and 5-30). It used right at half a bottle in 5,000 miles. I talked to the mechanic that was working on my car and he replaced the PCV valve and cleaned the intake for me.
That was the only time it was ever right below the full dot.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 04-04-2009, 07:28 AM   #12
*MAD DOG*
*MAD DOG*'s Avatar
I don't need to replace oil between servicing. Always stays the same level.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
embarrassingly bad mileage... REALLY XYaris Fuel Economy Forum 83 05-05-2009 04:47 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
