Old 04-02-2009, 12:01 PM   #1
GreenSpeed
Drives: '08 Yaris LB
Depot Projectors....make an offer
These have a story behind them.
When I purchased this set off eBay for $228, one of the lights came with a broken plastic tab/fastener (the upper one that screws in near the strut). I tried some creative ways to fabricate some metal to bridge the gap and when I was installing the lights, it was about 15 degrees out and the broke another tab due to the rigidity of the plastic.
So, on to more mistakes....
I decide to test out the LED's before I install them on the car. Being that I'm a complete moron when it comes to electrical measurements, I decide to hook up a 9 volt battery to the LED's to see what they look like. Flicker, flicker, then they die. I didn't get a clue the first time, so I killed the LED's in both lights due to a 9 volt current on a 3 volt light.
We're not done yet. I pick up some new LED's at radio shack for the Halo's which I was successful in soldering in place of the burnt out ones. It just so happened that the smallest white ones Radioshack sells are too large for the little slots where the halo LED's go. Out comes the dremel and I proceed to make the hole slightly larger. Little did I realize that it would send a cloud of plastic particles into the sealed headlight housing!!!
My kids learned a few new words from me that day, I'm ashamed to say.
I then proceed to bake the lights so I can get the housing apart to clean the inside out. That went pretty painlessly. That is, until I was putting new silicone sealant around the lights and got some on the inside of the housing. I made the mistake of using Goof Off on the inside of the clear light shroud and it had a chemical reaction with the plastic causing it to immediately blur. I at least had the smarts to stop immediately, but I now had a 3-4 inch blur spot on one of the lights.
I go to Autozone and pick up a plastic polishing kit and even wet-sanded the area with 2000 grit, which got rid of the blur, but did not remove all of the ultra-fine scratches.
I put a couple of coats of tint on the exterior of the lights to help mask the imperfections, which can easily be removed with pain stripper (I already used that once without any problems since my first tint job was way too dark, so it can be easily removed without damaging the outside again.
In all, this was one of the worst car mod disasters I've had, other than a custom front mount intercooler for my old STi. I hate the projects that only get worse with every new fix it idea.
So, now that I have unfolded my nightmare, these are still good looking lights that can be fixed with some TLC and some more plastic polishing. I'm offering these lights to the highest offer. Shipping is set at $40 anywhere in the lower 48.
The replacement halo LED's should work fine, but the upper 3 LED's on each side are toast, so you will need to pick up new ones from autolumination.com or somewhere else.
I purchased a brand new set of the same projectors and thankfully didn't make the same mistakes again.
Best offer takes 'em. Oh, and the eyelids are NOT included.
GreenSpeed is offline
Old 04-02-2009, 12:12 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Wow! I really like how the eyelids look on the depo headlamps...
Good luck with the sale.
tk-421 is offline
Old 04-02-2009, 12:24 PM   #3
I already have a set, but damn, you've given me ideas
eTiMaGo is offline
Old 04-02-2009, 12:30 PM   #4
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
been really really craving for a chance to get a pair of these, but don't think I am mechanically inclined to fix them...
Club SHIFT
TickleTimeTim is offline
Old 04-02-2009, 01:12 PM   #5
GreenSpeed
Glad I could you inspire you Thomas...at least with my lack of common sense. LOL
Old 04-02-2009, 01:17 PM   #6
Good story, sorry for your pain...
Sounds like you're describing all of my projects.
cali yaris is offline
Old 04-02-2009, 01:39 PM   #7
wow, that's a hefty project. you have a PM
KCALB SIRAY is offline
Old 04-02-2009, 01:49 PM   #8
GreenSpeed
1st offer is in....I'll give it a day or so before I take the highest offer. For those of you who are wondering, the original headlight bulbs will ship with the lights. Also, the upper LED's are the wedge type that simply plug in, so if you can find some, they plug in without taking the lights apart. The lower white LED's I upgraded to are brighter than the stock ones and look great (I'm actually going to upgrade my current dim ones). The lights come with the original wiring, ect.
Old 04-02-2009, 01:51 PM   #9
GreenSpeed
True that Garm...LOL
BTW...Those are your eyelids with my shoitty paint job.
Old 04-02-2009, 07:03 PM   #10
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
$100 + shipping
Ever blown out an R-200 diff god know's I have
ztrack157 is offline
Old 04-02-2009, 09:53 PM   #11
Wisher23
Drives: LB
could you point out the broken tabs in the pictures?
Wisher23 is offline
Old 04-03-2009, 09:39 AM   #12
GreenSpeed
broken tabs are at the top of the third picture and at the bottom of the 4th picture.
Ztrack...you are just ahead of the last highest offer. I'll go with the highest offer by noon MST today.
Old 04-03-2009, 09:16 PM   #13
GreenSpeed
Sold to KCALB SIRAY!
SEDAN PROJECTORS cali yaris Micro Image 245 02-25-2010 09:56 AM
The Home Depot layoffs jclo3313 Off-topic / Other Cars / Everything else Discussions 32 01-28-2009 10:06 AM
FS TL PROJECTORS sam07yaris Items for Sale by private party 3 07-06-2007 04:18 PM
