Old 04-04-2009, 10:38 AM   #1
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
What about cut the springs?
Some one told me that just cut one circle of the springs and the drop just going to looks perfect without loosing stock ride. They're doing that on a few Yaris here. My question is what can I really get if I do that? I'm not pretending to do that. What you guys think?
Yaris_PR is offline   Reply With Quote
Old 04-04-2009, 10:55 AM   #2
Advantage:
1) absolute cheapest way to lower your ride
2) Keeps comfortable ride (on small bumps)
Disadvantages:
1) Are you sure you can cut each spring exactly the same? Very easy to mess up the balance of the car.
2) Shorter springs that are not stiffer, think about it... They will reach the maximum of their leftover compression faster, and hit the bump stops, BAM... not very comfortable
in other words... don't be a cheapskate
Old 04-04-2009, 11:11 AM   #3
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
It's also extremely DANGEROUS. That coil is wound to hundreds of pounds of pressure, the energy has to go somewhere...
firemachine69 is offline   Reply With Quote
Old 04-04-2009, 11:38 AM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
i assume he has to take the spring off to make the cut, so that shouldnt be an issue.
i know you can take half a coil off without effecting spring rate. a full coil may be pushing it.
Anytime you lower a car, you will effect ride quality. the biggest issue is the effect on the dampers, they just dont work as well lowered. your suspension geometry is altered as well. if you cut your stock springs, alot of times, it will be worse that using proper lowering springs. if you want to lower it a little and retain a somewhat factory ride, you should use the tanable NFs. they are just slightly stiffer than stock and just over an inch of lowering.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-04-2009, 11:39 AM   #5
Treyz
~ ambient one ~
Treyz's Avatar
Mira ... DON'T DO IT!!!
I already yelled at my cousin in Rincon when he had his Civic years back (is now a pro drifter with a hachi).
You can screw up your suspension which equals DANGER! This is because of the fact that as Thomas stated, the spring rate is the same there for the bump stops will hit a lot more.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 04-04-2009, 12:09 PM   #6
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
if you want CHEAP go with a set of ebay springs....
Old 04-04-2009, 12:38 PM   #7
detroiter
detroiter's Avatar
As far as the TRD lowering springs go, Toyota states directly that it does not affect suspension geometry.
Now about cutting the springs, I would just play it safe and spend $120 on a cheaper pair of springs and have peace of mind that my car isn't going to have something BAD happen to it due to something that could easily be avoided.
Old 04-04-2009, 02:00 PM   #8
supmet
Drives: 2007 4 Door Yaris
Good springs are 150-200. Cheap springs are 100 or less.
Replacing your axles is much more expensive. Years of paying a chiropractor is much more expensive. Getting in an accident when your suspension fails is much more expensive.
Plus you can tell when someone has cut springs by the way the car bounces all retarded and bottoms out on speed bumps, and people will laugh at you
Old 04-04-2009, 02:03 PM   #9
^ Progress, $144.95 shipped (a bit more to PR).
Cut springs give a crappy ride, unless you like bouncing up and down a lot. You can easily pick out the cars with chopped springs on the road.
Old 04-04-2009, 02:23 PM   #10
MadMax
MadMax's Avatar
Seriously, if it were that easy or the results that good, don't you think more people on here would have done it?
Be smart, be safe, buy shorter springs and take the proper route for dropping your car.
Cheers! M2
Old 04-04-2009, 02:37 PM   #11
BLAZINBLUEVITZ
ZENN(TEIN knockoff) springs on ebay are like 88 bucks for a 2inch drop....
Old 04-04-2009, 03:52 PM   #12
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
That''s a common practice here in P.R. but for Show and around the town driving but for highways....No comment most likely almost ever AE86 and toyotas around 80's have their spring cuts . For me in my opinion jump on Garm for those springs, if you want to take the trip I can help you out! I have bought 2 sets from Garm one Tanabe DF's that are great! and NF's that are pure LOVE! You can't go wrong with micro image best price on shipping for us!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 04-04-2009, 06:56 PM   #13
Treyz
~ ambient one ~
Treyz's Avatar
Lol .. yes it is .. true story out there.
AMBIENTLIFESTYLE
Micro Image
Old 04-04-2009, 07:15 PM   #14
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
No, just spend the $100 on the DF210s and be done with it. Don't cut the damn springs please. I see these Ahole drivers around my area bouncing up and down with cut springs and swerving around potholes and causing drivers behind them to slam on their brakes because the ricers have to slow down so much. Next time i see someone do that in front of me im going to ram the pushbar on my envoy straight up their ass
So please, just get real springs and don't cut them is the moral of the story.
Old 04-04-2009, 07:50 PM   #15
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I still dunno how you get away with cutting springs....they taper off the ends or coil it tighter....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-05-2009, 03:34 PM   #16
ddongbap
Lol. If you end up screwing up your suspension, I'm sure you can find a new stock setup for 50 bucks or so.
IMO, I'd cut the passenger side a bit more, so you can offset the balance with your weight.
But IMHO, just get some coil overs.
But if you're going to ghetto it, ghetto it safe.
Old 04-07-2009, 04:41 PM   #17
33OH
Drives: '08 Yaris
That should be a bumper sticker.
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Which lowering springs should I choose? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-28-2009 05:56 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
