#1 |
back lit control?
First night out with the car I noticed that the pod that holds the mirror switch, and cluster dimmer control is not back lit, nor is the controls on the driver side door IE: the door locks, window locks or the other window switches (the auto down is lit.) The passenger door switches aren't back lit either. Is this just mine sedan or aren't any of the sedans back lit? I also noticed the the radio controls and three knobs that control heat and air are also a quite a bit dimmer than the speedo cluster. If you dim the speedo cluster to a comfortable level then you can't see the display on the radio very well. I have the square faced radio with the buttons down each side.
Any input? |
| Digital Gauges, Auto Climate control, Manu-matic shifter | computerlove87 | Cosmetic Modifications (Exterior/Interior) | 21 | 12-02-2012 11:55 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Back hurt? | yarswiss | Off-topic / Other Cars / Everything else Discussions | 10 | 11-14-2008 04:39 PM |
| Rear wiper: EZ mod so it pulls back all the way | joelitton | Cosmetic Modifications (Exterior/Interior) | 10 | 10-22-2008 10:30 AM |
