Old 04-07-2009, 10:24 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Beathrush alluminum underpanel / skid plate
http://cgi.ebay.com/ebaymotors/Beatr...ht_2506wt_1440
According to this linke it should work for all yaris even sedan as long as its a 06-08. I remember seeing a post back before the hack of someone trying to get it to fit on the US model yaris but wouldnt fit exactly.
Unless they have redesigned a US model version....
Someone really has to custom design one. One maybe out of plastic and one out of aluminum for a much more affordable cost than near 200 most i would pay is 100
Old 04-07-2009, 11:39 PM   #2
mrbond
mrbond's Avatar
It's not likely it'll fit a sedan: the hatchback and sedan have two different bumper designs. The bolts at the bottom would doubtfully line up. You could drill new holes in the bottom of your bumper, but that's all I can think of.
That's a really good deal...I might think seriously about it...
- A Toyota Yaris
- A whut Yaris?
Old 04-07-2009, 11:42 PM   #3
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
It won't fit I own the CONE model essentially the same thing and I had to mod it to fit the hatch
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 04-07-2009, 11:59 PM   #4
YarisSedan
Hmm. I think my shop has a old skid plate laying around somewhere. I may try to use that first since its easier to cut. And the the basic layout and design first and then trace it on top of the aluminum sheet with a permenant marker and make the cuts. And taking my tiny dremel cutting tool and a handy drill and making my own custom one. Then once its done and perfected i can have a template for other members.
Old 04-08-2009, 12:10 AM   #5
ChinoCharles
Drives: LB
D. I. Y.
Old 04-08-2009, 12:10 AM   #6
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I just realized why I haven't considered one yet. You have to remove it every time you change your damn oil
Old 04-08-2009, 01:04 AM   #7
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
I tried to get it to fit. No luck on my end. Too much custom work. I sold it locally to a hatch owner. I did however make a template of it. I just need to get back out in the garage and make a template for the sedan bumper and custom cut one. If it ever warms up I will start back on it. The mounting points on the rest of the plate did seem to line up though.
As far as oil changes....I plan to cut out a hole just big enough to get a wrench on the drain plug and filter.
