Old 04-10-2009, 03:31 AM   #1
The importance of having strong nuts :D
could not resist the title
But, yes, a bit of a warning about cheap lightweight aluminium lug nuts... Don't overtighten them:
On the left, a normally tightened one, on the right, one which was tightened with herculean might... On the side where I had the accident, so I don't know WTF the body shop used to tighten them. Went for a wheel balancing and rotation yesterday and we noticed this... Lucky my wheels did not fall off!
Old 04-10-2009, 08:00 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Happens all the time to steel ones, too, when those pneumatic impact wrenches are misused. I was once head-oned by the P215-75R15 wheel and tire from the left front of a big Oldsmobile Cutlass. It bent the front bumper of my 1983 Dodge Ramcharger into a V and broke the grille behind it, also damaging the air conditioning condenser. As the thing had been bouncing head high, I was thankful it hit me at bumper level! We were going about 40 MPH in opposite directions, it would've been worse at highway speed. Stripped lug nuts. My wife also once had the left rear wheel of her Mustang come off and pass her. Same thing. I've encountered stripped nuts several times when I went to remove a wheel with a lug wrench and found the nuts would turn but not back off.
Old 04-10-2009, 08:09 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Isn't it even more common if you use the aluminum lugs? I've been told if you don't use anti-seize on aluminum lugs with steel threads that they can seize together easily and strip.
I think I'll stick with steel lugs for now.
Old 04-10-2009, 08:12 AM   #4
Yaris Hilton
Smile
Frankly, I think aluminum lug nuts are an appallingly stupid idea. But with either type, you have to use some common sense and follow proper installation procedure.
Old 04-10-2009, 08:59 AM   #5
d1nzfe
Drives: 1NZ-FE
my muteki seems to be very good till now
d1nzfe is offline   Reply With Quote
Old 04-10-2009, 12:58 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Yeah its called impact gun level number 5. This is why i hand torque all my lugnuts to 76 ft lbs manufacture specifications. Only gun them on on number 1 and hand torque them the rest of the way. Funny thing is even at number 1 sometimes the torque wrench clicks. So id be afraid to ever use number 5.
Old 04-10-2009, 01:13 PM   #7
kurokoma-kun
Drives: 2007 Yaris HB
those brutes!
tire shop guys did the same thing to mine once, which is why I split my spline drive adaptor trying to get them off later. hand torquing, its the only way to go
What lug nuts do you recommend me for OEM alloys? TitaniumBarbell Cosmetic Modifications (Exterior/Interior) 5 04-05-2009 12:10 AM
lug nuts...? at3GG Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 03-26-2009 10:16 PM
Team Daytona Racing Wheel nuts (RAYS) saspy Items for Sale by private party 0 03-19-2009 08:04 AM
Cheap Lug Nuts? KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-06-2007 12:51 AM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 05:58 PM
