#1 |
Riceman43
Help on hooking up amp..
Ok ive been out of the car stereo stuff since the 80's and all this new stuff is kind of got me mind boggled. This is what i will be hooking up
http://cgi.ebay.com/Soundstream-Pica...408153006r6722 Along with 2 12" Alpine Type R woofers..Now whats got me messed up is the woofers come with some kind of jumper wires what is the best way to hook both of the woofers up to this amp.. If someone would make a diagram at works properly i will pay you 10.00 on paypal..lmao... |
![]() ![]() Drives: 08 Hatch Join Date: Mar 2009
which Alpine type Rs, Dvc 2 ohm or dvc 4 ohm?? i can draw the diagram
#3 |
Riceman43
4ohm
#4 |
http://www.rockfordfosgate.com/rftec...2&woofer_imp=4
there are to options there,, you probly want to run them at 1 ohm that way yur amp is running cool, if you run them at 4 ohm you be short on power. |
#5 |
Riceman43
Still confused since my - and + on the alpines are in a straight line not across from each other.
#6 |
wire all the negatives on each sub together and wire the positives on each sub together. than run from 1 negative on each sub to the negative terminal. the only difference of your sub is wear the terminals are jus remember the first positive and negative are one voice coil and the next two are the other instead of being across from eachother. so use the diagram to help yu. than those subs are going to be rockin
#7 |
Riceman43
ok as soon as the amp and other woofer get here i will hook up and if everything works like you say..i will send you 10.00
#8 |
deall
| Amp And Cable Kit Question | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 01-28-2009 06:59 PM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
| Connect mono amp. + subwoofer to stock HU? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 10-28-2008 10:01 PM |
| small 4ch amp. 4x100rms | ben dover | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-08-2007 04:17 PM |
