Old 09-02-2006, 11:23 AM   #1
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Ruba a dub dub in the rear
Well the 215/40 17's officially rub in the rear. The front is what I was worried about and the rear is what I should have been worriend about. Me and my dad were riding around in it yesterday and was hearing the back rub a little as we hit some bumps. When we got out we noticed that the fender in the rear sticks out more in the rear then in the front, but with me and my dad we probably had over 500 pounds in the front seat. Anyone who has a sedan go look and see what I mean. So I am thinking about rolling the fenders all the way around or getting 205's. Suggestions??????
Old 09-02-2006, 12:01 PM   #2
riceboy
Drives: icebox
Get the 205's... it'll save you a lot of trouble.... You'll probably be able to sell the 215's no prob...
riceboy is offline   Reply With Quote
Old 09-02-2006, 02:42 PM   #3
slvryaris
slvryaris's Avatar
Anyone want to buy a set of 215/40/17 Toyo Proxy 4???? I was thinking of putting them on Scion Life, but would rather put them on here first. Anyone interested P.M me or post on here. I will sell them mega cheap...
Old 09-02-2006, 03:33 PM   #4
ChinoCharles
Drives: LB
Can you put 215's on the front and 205's on the back? Or would it drive funny. It would be cool to have more rubber on the front, where the power is... kinda like the FWD drag cars with slicks on the front.
Old 09-02-2006, 04:49 PM   #5
riceboy
Drives: icebox
You may want to try and sell them on other boards.. you might be able to either make some money, or regain what you put out.... the subby and evo guys are a decent bet... otherwise the scion guys might pick up off you quick too...
Chino - you'd have trouble with it if the heights are off... i don't think 215-40-17 and 205-40-17 will set level....
Old 09-03-2006, 05:48 AM   #6
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
slvryaris you said that it rubs at the rear with 215's. I am running the same setup but in no ways what so ever am I getting any problems. What suspension setup are you running?
DollaZo is offline   Reply With Quote
Old 09-03-2006, 09:44 AM   #7
slvryaris
slvryaris's Avatar
I am running the NF210, but I am not by any means a little guy. I had me and my dad in the front seat of the car at we are probably at a combined weight of over 500 pounds. I am sure that you wil be fine unless you have some big people you like to take around, but if its just you and a lady most of the time you wil be fine depending on how low you bring it down with springs. With the Austrilian 5 door hatch the inner fender lip might be different.
Old 09-04-2006, 12:38 AM   #8
ChinoCharles
Drives: LB
It was a nice thought though. Haha.
Old 09-04-2006, 09:56 AM   #9
03Z33
03Z33's Avatar
Drives: TCR10
I would try rolling first... it should be very minor rolling. You will also benefit from the slightly taller diameter of the 215 tires since you didn't lower the car as much, they will help fill in the wheel gap .
As mentioned, I run 215/45/17 RT615's on 17x7 +38 wheels with the DF210's and with the hatch fully loaded:
6 spare wheels and tires = 120lbs
tools = 30lbs
jack = 20lbs
myself = 220lbs
passenger = 170lbs
total = 560lbs
and still no rubbing! It may be the difference in body lines between the LB and sedan? Also I did have rubbing up front at first, but I purchased the smallest diameter camber correction bolts from Toyota = 12.4mm and it's all good now I'm sitting at -1.2 deg front camber and it's much nicer than the stock -0.5!
03Z33 is offline   Reply With Quote
Old 07-22-2007, 11:25 AM   #10
hey 03Z33, where would one get those bolts? Got a link?
Might solve the tiny bit of rubbing I get too.
Old 07-22-2007, 08:27 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
They are from Toyota. I'd search for the part numbers for you but I'm replying from my cell and can't get it to work. Just search my old posts, I've posted the part numbers a few times before.
