Old 09-02-2006, 08:38 PM   #1
H8SGAS
H8SGAS's Avatar
Drives: Black Liftback
Interior Door Panels
I’m having an issue with the interior of my liftback which I picked up last Friday and I was wondering if any of you have experienced it as well. It seems anytime I touch (yup touch, with the pads of my fingers ) the surface of the light grey paneling near the crank for the window/front speaker it changes color and appears faded and scratched (turns an off white color like when you use your hand to erase chalk from a board.) Smoothing the "fabric" in the opposite direction like one would do with microfiber only makes the white mar worse! I have yet to try any forms of removing the marks other than the "good ole lick the thumb and rub" method which left a lovely larger and wider discoloration so I left the rest alone….…. figured I’d ask before calling the dealer or trying some armor all. As of now I can see everyplace I have touched the door panels.
H8SGAS is offline   Reply With Quote
Old 09-03-2006, 09:10 AM   #2
msagowitz
Drives: 07 Toyota Yaris Sedan
Yeah I have noticed the same thing...it looks terrible. I tried to armor all the interior, and it ended up looking worse. It just makes it look real unevenly glossy.
msagowitz is offline   Reply With Quote
Old 09-03-2006, 10:27 AM   #3
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Just clean the interior with a damp cloth
dust it with a swiffer cloth
products containing silicone and teflon will fade the plastic over time and then it will look like crap.
Old 09-03-2006, 10:27 AM   #4
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Oh yeah it sucks.However, I discovered a special leather made fabric(Wettex) that removes these white spots, when applying water on the panel.
Imagine that mine has black paneling, so it is even worse!
Old 09-03-2006, 07:08 PM   #5
H8SGAS
H8SGAS's Avatar
Well mine are black too (as well as the car) I was thinking about the next thing I posted regarding removing the gray A-Pillar....DOH!!! I think I’ll give a damp cloth a shot before asking the dealer, if both fail where did you find the Wettex? Swifter cloth sounds great those things are awesome. If I do wind up inquiring to the dealer I’ll update yall on what they say.
Old 09-03-2006, 07:45 PM   #6
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
My guess is they prepped the car with something. Maybe you should check with the dealer if a damp cloth won't clean it off.
Old 09-04-2006, 01:30 AM   #7
Katana
Katana's Avatar
Wettex is a kind of cloth that absorbs water and helps u clean the dirty surface.
