Old 04-16-2009, 02:19 AM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
got better milage with silencer
Well got bored this last month and tired of the drone from GReddy tic so I put in the silencer,my last two tanks of gas I am now averaging 36-36.5mpg where as the tanks before it I only averaged 33.5-34mpg,same amount of gas,same type of driving both tanks all freeway shor t of about 20 miles a tank,driving about 60mph.
Has anyone else had their milage go up by putting in the silencer and any thoughts on why,I use the same gas from same station every fillup,record miles religiously,and only other mod is Ingen CAI,tires same air pressure,temps outside pretty much the same all month.......
Car does not seem to respond any slower of the line or passing with it in so I am leaving it in ,CAI is louder than exhaust now,but that is ok,it got old on the freeway trying to listen to radio.
Old 04-16-2009, 08:33 AM   #2
markitect
This isn't all that surprising. Modern vehicles use backpressure to improve fuel economy. Basically it's designed for the pressure caused by the normal exhaust so when it recycles exhaust gas the valves only open a little on the intake cycle. When there is not as much pressure more fresh air is used, so more fuel is required.
markitect is offline   Reply With Quote
Old 04-16-2009, 08:36 AM   #3
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Did you reset your ecu after installing any of your mods?
The Spectacle is offline   Reply With Quote
Old 04-16-2009, 11:51 AM   #4
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
Wow, I grew up in University Place.
Old 04-16-2009, 12:12 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
backpressure..
Old 04-17-2009, 10:57 AM   #6
toyo
Drives: toyota
thinking about putting a silencer on but it's bigger than the OEM one, hope it reduces the sound, I just don't like the muffler previous owner got for the yaris, cheap as hell!
toyo is offline   Reply With Quote
Old 04-17-2009, 10:03 PM   #7
bzinn 1
bzinn 1's Avatar
Ok that does make sense it is gettign a bit more backpressure and it is helping.Think I am gonna keep it in too......It is not as punchy off the line to say 15mph,but after that it feels the same as without it,and it is so much quieter,only real volume comes under load with pedal down to floor.
Yes reset the ECU on every new item on car,also own a tC and am used to doing this every time I add something,drives me nutty to have to do it too especiall on the tC as I always have to reset everything on the stereo.....takes a good hour to retune it all back in.
Old 04-17-2009, 10:04 PM   #8
bzinn 1
bzinn 1's Avatar
Also thanks for the answers guys.....I thought I was going a bit loopy or something,may put stock one back on to see if I break the 35mpg mark,if so it will stay on and sell the Greddy.....lol
Want to improve your gas milage by 18%-20%? Crandall Fuel Economy Forum 22 02-11-2009 10:11 PM
Increase your gas milage with Acetone??? captainm27 General Yaris / Vitz Discussion 9 11-06-2008 08:42 AM
Huge Gas Milage Reduction from installation of intake YarisSedan Fuel Economy Forum 14 10-22-2008 09:09 PM
How to Increase Gas Milage Pavel Olavich Performance Modifications 9 03-20-2007 07:58 AM
