Old 04-20-2009, 04:20 PM   #1
SweetRS
Drives: 2006 Yaris Rs
SQUEEKY brakes
whenever i release the brake pedal, theres a loud squeek....assuming calipers need lube?
SweetRS is offline   Reply With Quote
Old 04-20-2009, 05:54 PM   #2
brake shoes needs cleaning.
Old 04-21-2009, 08:50 AM   #3
SweetRS
sweet. thanks!
Old 04-21-2009, 09:17 AM   #4
i do hope you know that when i said brake shoes, i meant rear brakes right ??
Old 10-01-2012, 02:01 PM   #5
gtrail
Drives: 2008 Yaris sedan
My brake shoes rub against the backing plate. What grease can I put on that won't ruin my brakes?? Thanks!
gtrail is offline   Reply With Quote
Old 10-01-2012, 09:54 PM   #6
clarenceie
Drives: Yaris Sedan
You can try some anti-seize where the shoes touches the backing plate. Just a fine layer...
clarenceie is offline   Reply With Quote
Old 10-01-2012, 10:02 PM   #7
dragoonmc
Drives: 07 hatchback
or there is brake grease that they sell in the autoparts stores
dragoonmc is offline   Reply With Quote
Old 10-02-2012, 12:04 AM   #8
CoryM
Drives: 2009 5-door, 5-speed
Assuming the squeak is from the rear (and it should do so when e-brake is pulled/released too):
Use a screw driver to gently pry the shoes away from the backing plate and apply a thin layer of anti-seize to the 3 spots that shoes touch the backing plate. Clean most of the dust out, and adjust brakes. Chances are if it's moving enough to make noise, you are way out of adjustment. If you were to sand the shoes, and remove the sharp edges, you have just completed a "rear brake service and adjust" and you can charge yourself about $50
Cheers.
Old 10-02-2012, 05:00 PM   #9
nookandcrannycar
Absolutely. I heard the same sound, took my car in (not to the dealer) and the shop showed me what was wrong. They did the job (very inexpensively), and the sound disappeared.....and of course = rear brakes only.
A few questions about suspension, tires, and brakes. supmet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-02-2009 04:55 PM
Weird question about my brakes brainless twit General Yaris / Vitz Discussion 8 01-22-2009 10:59 AM
Brakes Geelmeel General Yaris / Vitz Discussion 16 06-29-2007 07:58 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
