Old 04-22-2009, 02:20 AM   #1
YarisFan007
YarisFan007's Avatar
Drives: 2007 Toyota Yaris HB
Crazy glue!?!
The other night I had a major flat on my left rear tire after I ran over a long screw nail. Within about 10mins after I had pulled out the nail the tire was completely deflated.
My uncle told me that he could repair the punctured tire by applying Crazy glue to it. I didn't believe such a fix could repair it but it actually worked!!!
He had sealed the hole that night and I've been driving with it ever since... It looks like it really works... the tire doesn't seem to be leaking air.
My uncle said he has done this several times w/ other tires and they've never had a problem w/ Crazy glue.
Has anyone heard of this miracle?
YarisFan007 is offline   Reply With Quote
Old 04-22-2009, 02:45 AM   #2
I dunno, I'd be a little worried about driving.
Old 04-22-2009, 07:29 AM   #3
MadMax
MadMax's Avatar
How much have you driven on it? I ask because if you haven't done many highway miles, the tire hasn't heated up enough to really "test" how well it is holding.
And I agree with Kaotic, I would have the tire properly fixed or replaced. What risk a $13K+ car to a super glue repair of a tire?
Cheers! M2
Old 04-22-2009, 11:15 PM   #4
YarisFan007
yesterday it was about 97degrees fahrenheit here in the valley, and I drove it around the city and highway for miles. So far it's fine- no leaking. But like I said, my uncle has done this to my aunt's Acura when she had a punctured tire last year and ever since then the tire is fine.
who woulda thunk it? lol
Old 04-22-2009, 11:20 PM   #5
YarisFan007
by the way, this was an industrial strength Super glue.
...if that makes it any better. lol.
Old 04-22-2009, 11:25 PM   #6
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
just so you know places like discount tire and america's tire will do a flat repair for free...they just end up charging for the balance....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-22-2009, 11:33 PM   #7
YarisFan007
how to they fix a punctured tire exactly?
Old 04-23-2009, 12:05 AM   #8
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
grind and smooth out inside of the wheel, apply a high pressure patch, then use a special tool that seals the edges of the patch. put it back on and its good to go
Creeper is offline   Reply With Quote
Old 04-23-2009, 01:45 AM   #9
Shroomster
Shroomster's Avatar
yeah pretty much; best way to fix a puncture is an internal patch with a plug that seals the injury form the inside and through to the outside...
Old 04-23-2009, 01:50 AM   #10
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Better put a plug in it. You can do it yourself. Just get the kit from a local auto store.
Old 04-23-2009, 08:00 AM   #11
33OH
Drives: '08 Yaris
+1, it's really easy and will cost you maybe $10.
Old 04-23-2009, 10:39 AM   #12
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I can see Krazy Glue as a temporary fix. It's not going to be affected by the temperature that a tire tread reaches. The problem with it is that it dries solid, it's not flexible. So, as the tire flexes, it could break its bond with the rubber and leak... or work itself out... or crack and break. Krazy glue is brittle stuff.
Nice, simple emergency repair, though. I like it.
Old 06-04-2009, 12:31 AM   #13
YarisFan007
Just an update- It's been about a month and a half since I superglued my tires and so far it's still running fine. No leaks whatsoever ; )
Old 06-04-2009, 12:48 AM   #14
YarisSedan
Drives: 08 Yaris Sedan
Hmm something else we need for the glovebox emergency roadside kit.
Old 06-04-2009, 12:49 AM   #15
YarisFan007
fo shizzle
Old 06-04-2009, 02:16 AM   #16
JBougie
JBougie's Avatar
$3.99 @ Walmart, and you'll never have to question if it will work or not:
JBougie is offline   Reply With Quote
Old 06-04-2009, 06:40 AM   #17
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
yup ill have one in my car too...did you seal it from the outside? how was it done? oh and i run on nitro...wold that be bad for the tire? bad chemical mix? whooo...scarry!
but that is interesting though!
msfire671 is offline   Reply With Quote
Old 06-04-2009, 12:16 PM   #18
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
After building models all my life, I know a bit about adhesives. "Krazy Glue" is a cheap version of cyano acrylates (CA), which comes in various grades and viscosities. For a temporary tire repair, the thinner the better; it allows the adhesive to penetrate farther. When building models, the slip of a knife can often call up the use of CA, and it works very well, sealing the cut and stopping the bleeding instantly. Eventually, the oils etc in the skin will break down the CA, and no scar is left.
Any problem that would develop has to do with how clean the hole is, ie, and debris in the hole could interfere with the seal. And once that stuff is cured, it is VERY hard for any separation to occur. Yes, it cures into a brittle substance, but not all CAs are the same; some are more brittle than others. Considering the size of the hole, I really don't see it as a big problem.
Besides, after 100 miles or so, it would take a sharp eye to find the hole again!
Am I crazy intioumaximus New YARIS Purchase Forum 11 04-20-2009 07:11 PM
Going Crazy at the Parking Lot derickveliz2 Photo-Video-Media Gallery 33 02-03-2009 11:38 PM
Crazy Old Lady's Driving Grand Marquis!! Watch Out!! YarisGirl82 Photo-Video-Media Gallery 26 10-01-2007 07:01 PM
crazy yaris sites acrbill General Yaris / Vitz Discussion 4 02-27-2007 05:05 PM
Crazy bodykit. Yaris Yaba Cosmetic Modifications (Exterior/Interior) 15 08-23-2006 01:10 AM
