Old 04-23-2009, 06:37 PM   #1
1NZYaris1
1NZYaris1's Avatar
Advice need PLEASE
hello people , i have just bought the following speakers.
below is the sales blurb , i got them for $139.00NZ shipped.
The Question i have is do i need a amp to run these and can i run them
with out the crossover , as i also have a set with no cross overs.
Probably silly questions ,but i have never used component speakers as such before.
Specifications
732Compliance (Cms)11.3Cone Area (Sd)3.6D.C. Coil Resistance (Re)0.61Electrical Q (Qes)4.897Force Factor (Bl)53Free Air Resonance (Fs)55Hz-22kHzFrequency Response4Impedance (Nominal)Magnet Structure (Oz)260Max Power (Watts)10Mechanical Excursion (mm)3.47Mechanical Q (Qms)65mm (2 9/16")Mounting Depth131mm (5 3/16")Mounting Diameter85RMS Power (Watts)88Sensitivity (dB) (1W/1M)0.519Total Loudspeaker Q (Qts)Reactor
6.5" Component Speaker System
RE-CM650
RRP $229.99
More power, more quality and more bass - Reactor is the angry upgrade to FUSIONs Encounter car audio range and is dripping with technology.
Reactor speakers take the sweet sound handling capabilities of Encounter to the next level. Combining quality close-tolerance polypropylene cones with silk-dome tweeters to produce better sound definition.
Component Speakers feature 3-way attenuation sensitivity to control the level of tweeter output at -3dB, 0 or +3dB and small crossovers for discrete installation.
Butyl rubber surround
Polypropylene cone
High efficiency magnet structure
Round-wound copper voice coil
Pressed steel basket with rubber boot
Silk dome tweeter
Old 04-24-2009, 12:03 AM   #2
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
If you have an aftermarket deck then no, you shouldn't need an external amp. You should also be able to get away with not using a crossover for 1 set but personally, I would put them in the back as your not going to hear the highs as well as you would if you put them in the front. If you only have one set and no crossovers, I would look into getting some because that would really make a difference in the sound quality.
smofskra is offline   Reply With Quote
Old 04-24-2009, 12:26 AM   #3
1NZYaris1
1NZYaris1's Avatar
Sorry , i have one set with cross overs and one set without .
Running factory head unit . For know .
Old 04-24-2009, 12:30 AM   #4
Isn't the RMS some what high for a stock HU? I heard it's also bad to stray away from the RMS in either direction.
Old 04-24-2009, 01:00 AM   #5
1NZYaris1
1NZYaris1's Avatar
Stock head unit is 50watts rms , other than that don't know .
Sterio's aren't my thing , i have no problem wiring them up just trying to
find out what is best for them. To get the best sound
Old 04-24-2009, 02:12 AM   #6
smofskra
smofskra's Avatar
i believe that the 50 watts rms on the stock deck is total power. its like 12.5 rms per speaker. upgrade your deck before your speakers.
Old 04-24-2009, 08:43 PM   #7
Yeah, that's what I thought too.
Old 04-24-2009, 09:04 PM   #8
skigil
skigil's Avatar
Drives: 2008 Yaris Hatchback
upgrade both.
A good quality speaker is useless without something nice to drive it.
A good quality amp is useless unless it is going somewhere nice.
You have a somewhat nice set of speakers here. At least get a decent head unit to drive them. If you'd like to get crazy, get a crappy headunit and a nice amp to drive these.
skigil is offline   Reply With Quote
Old 05-03-2009, 02:10 PM   #9
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
You need to run them with the crossover, or the tweeters will be destroyed right away from the midrange frequencies.
If you really need to use them without the crossover, you can just hook up the woofers and not the tweeters.(this would be fine for the back speakers, for example.)
Old 05-04-2009, 02:16 AM   #10
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
run the crossovers...its best for the speakers...
P.S. the speakers wont sound as good with the stock head unit, but I have yet to see a pair of speakers destroyed from putting a higher watt RMS aftermarket speaker on a factory deck. just don't crank it till they clip. if you hear distortion, turn it down, and you wont blow the speakers or the head unit. pretty simple concept really.
Old 05-04-2009, 03:24 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
There’s a lot of good points that have been mentioned here. Take a look at it from this point of view…
Should you use a component set over the stock system? Yes, in most cases.
That being said, should you use an aftermarket deck to power the fore mentioned component set? Sure, depending on your needs for the system.
The next logical question would be will the component set sound better when run off deck power or amplifier power? Depending on the amplifier, most definitely.
Think about the last sentence for a second.
Do I use the deck’s claimed 50 Watts x 4 or an amplifier’s 50 Watts by 4?
Take a look at the difference:
Here’s a reputable Amplifier that runs 45 Watts x 4:
…and of course I can’t find a picture of a deck amplifier board. Given that, you can use your imagination. The entire deck isn’t a 1/3 as big as the 45 x 4 amplifier seen above. Grossly oversimplifying this, there’s a reason why a huge percentage of the SQ competitors use tuners as sources versus powered CD player sources. It sure as heck isn’t because the deck amplifier’s 50 or whatever Watts sound good.
Am I coming off as too snobby by saying all this? I sure hope not.
― Thomas Paine
Old 05-04-2009, 04:48 AM   #12
1NZYaris1
1NZYaris1's Avatar
Thanks everyone for your input , i installed the above component speakers
at the weekend , and it is a diffenant improvement over the speakers that
was there , the next step will be to run it all through an amp or 2 ,
Of which i have never used or done before , but there's a first time for everything, so off do read some more post to work it out
Good advice for new car owners... YarisSedan General Yaris / Vitz Discussion 10 04-15-2009 03:43 PM
Just purchased new Mary Kay consultant package. Any advice for getting started? Nicholas1 Willing to Buy by private party 6 01-14-2009 04:48 AM
Legal advice needed Rahxephon Off-topic / Other Cars / Everything else Discussions 8 09-24-2007 04:56 PM
More advice please littlecarlove Performance Modifications 8 11-05-2006 02:46 PM
