Old 04-24-2009, 07:37 PM   #1
Pitt Yaris
Drives: Flint Mica Sedan
Self Painting Upper Grill
Obviously I have to get the aerosol can from automotive touchup which is 20 bucks but I'm trying to spend less than 8 dollars for primer and clear coat. Any suggestions? I don't think I'm going to get adhesion promoter. Just use a special primer for plastics. I'm trying to keep this total job under 100 bucks. (Grill is $60 with shipping, flint mica is 20 plus $9 shipping *90bucks*) Also, what are opinions on wet sanding? Does it really need done?
Old 04-24-2009, 08:02 PM   #2
I think wet sanding is to take down any unevenness (orange peel effect for example) after you paint. Yes? I'm not a painting guru, that's for sure.
Old 04-24-2009, 09:01 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Professional looking painting can be done with areosol can. Make sure you shake up the can a ton before you do it. Then lightly wet sand the area down very well. Then wash the area with dawn dish soap to remove all residue and wax.
Then with the can hold it about 5 inches or so away from the surface and gently mist the panel you are painting not actually spray it. In short burst in a sweeping motion.
That is the only way to blend the area. If you have a hair dryer. Dry the area for a few minutes. Then go again with another coat. Or just do it on a really hot sunny day. Once you have even coverage let it dry for awile.
Once you feel it is fully dry hit it with some rubbing compound to take out the little bits of overspray and to kinda even the tone out. Then cleaner wax. Then polish and then sealant.
After you are done it should look about 90 percent better and you should not be able to tell there was paint done unless you know where you are supose to be looking.
I know cause i just had to repaint my fathers bumper cause my mom hit the sidewalk with it. Popped the dent and then repainted one small section. It was a gold flake paint so was tricky to match.
If you got a solid color car you are more fortunate
Old 04-24-2009, 09:03 PM   #4
Pitt Yaris
I have flint mica so it sucks. Not sure how odd it would look if I just put it on as is. *Flat/plain black plastic* Saw a couple people do it, one did it with a silver sedan, but not sure about flint mica.
Old 04-24-2009, 09:09 PM   #5
I had black vinyl for eyelids before today. Went quite well with my flint mica. Just paint it either semi glossy black or flint mica. Flat black might be too dull looking for such as big piece.
Old 04-24-2009, 09:10 PM   #6
YarisSedan
Oh you are painting your vios grill. I am hella tired. I thought you meant painting like upper bumper like it was damaged lol.
I got my vios grill painted flint mica for 50 bucks. Parts and labor for everything. They preped primer, and clear coated it with lifetime warrenty. Check your local bodyshops you will get better results.
Old 04-24-2009, 09:11 PM   #7
Old 04-24-2009, 09:11 PM   #8
HOLY! Mine cost a little more than 3x that!
Old 04-24-2009, 09:15 PM   #9
YarisSedan
Really! I had my rear chrome piece painted for 20 bucks too i had it done at same time.
Old 04-24-2009, 09:17 PM   #10
Which/where is the shop you went to? My spoiler cost 10 bucks less to paint then my grill at the same shop
I'm thinking of going to your shop next time I need something painted.
Old 04-24-2009, 09:25 PM   #11
YarisSedan
its called eddies auto body in san jose. They got really good yelp reviews. Supose to be true bodymen. They do real bodywork not replace panels. Also supose to be the cheapest place in bay area. Suposidly they are always 1/3 the price of the competition.
Old 04-24-2009, 09:42 PM   #12
True that! Now I'm just piss that I paid ~180-200 to have my grill painted! Oh well, the shop I went to did an excellent job
Grille Thread.. Blenjar Cosmetic Modifications (Exterior/Interior) 40 11-14-2010 03:26 AM
New grille or not free297 Cosmetic Modifications (Exterior/Interior) 27 11-14-2010 03:21 AM
Opinion on front grill IllusionX Cosmetic Modifications (Exterior/Interior) 20 04-22-2009 08:53 PM
Sedan Grill Options tuckevalastin Cosmetic Modifications (Exterior/Interior) 15 12-29-2008 10:59 PM
DIY: Yaris Hatch grill block/air dam yarswiss DIY / Maintenance / Service 0 10-26-2008 06:52 PM
