Old 04-25-2009, 08:15 PM   #1
350zrb
Drives: 2008 Liftback
Just finished DIY NF210 but have question about the gap ....
Hi,
I just finished installing NF210 but i have about 1/4" space between the top cap and car body (top of the strut tower).
Is this a problem?
Thanks
Pat
350zrb is offline   Reply With Quote
Old 04-25-2009, 08:18 PM   #2
Put up a pic. I think this is something that many have questioned, and seems to be normal.
Old 04-25-2009, 08:32 PM   #3
350zrb
Got the pic but can't figure how to put in this thread.
Thanks
Old 04-25-2009, 08:33 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
www.tinypic.com
Old 04-25-2009, 08:34 PM   #5
350zrb
I attached the pic.
Old 04-25-2009, 08:36 PM   #6
Yep, looks like what others have reported.
Old 04-25-2009, 08:38 PM   #7
350zrb
I Just don't see how this can be OK.
The strut assembly is not really bolt on to the car if there is this gap there.
Old 04-25-2009, 09:54 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
Looks like you may have to tighten the top of the strut mount bolt a bit.
Old 04-25-2009, 10:06 PM   #9
350zrb
The first nut (below the cap) is already tighten. The second nut (above the cap) also tighten and wil not go down any more.
Thk
Old 04-25-2009, 10:52 PM   #10
mrbond
mrbond's Avatar
No, it's fine, actually. If you jack the car up, you'll notice that the gap goes away. I took my car to the local performance shop, and they said it's just the result of having lowered the car. No problem.
Btw, I'd put the little rubber cap back on if I were you...
- A Toyota Yaris
- A whut Yaris?
Old 04-25-2009, 10:52 PM   #11
tristan
it's been a while
tristan's Avatar
Drives: 2009 liftback
Yep mine look like that too, no problems. I have trd springs
tristan is offline   Reply With Quote
Old 04-26-2009, 12:22 AM   #12
350zrb
Yes, I will put the top rubber cap back on.
Thanks for info guys.
Old 04-26-2009, 12:29 AM   #13
frownonfun
frownonfun's Avatar
why don't mine look like that then? i have the tokico's and df210's. is it just some setups cause this gap and some don't?
Old 04-26-2009, 12:37 AM   #14
350zrb
What is Tokico? A strut?
I have original strut.
Old 04-26-2009, 12:40 AM   #15
frownonfun
frownonfun's Avatar
yeah, sorry, i meant the struts. tokico struts and df210 springs.
Old 04-26-2009, 12:42 AM   #16
detroiter
detroiter's Avatar
Tokico HP shocks/struts are upgraded "performance" based to make handling stiffer. It is designed also for lowered applications. As in if you put lowering springs on, these things go great with them because they help stop the "spongey" feel and help from rubbing, etc.
Old 04-26-2009, 12:45 AM   #17
frownonfun
frownonfun's Avatar
ok well i knew that i just didn't know if that was the reason there was no gap after putting these and the springs on. not that i'm complaining. the gap would bother me.
Old 04-26-2009, 12:59 AM   #18
350zrb
Yes, it's kind of bother me too.
I also cut the bump stop by 1.1"
May be I will put in hard rubber gasket into the gap?
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 10:02 PM
Tanabe NF210 Installed - Question spacemanoeuvres Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-15-2007 08:16 PM
DIY Tacho install question Capagotks DIY / Maintenance / Service 6 07-04-2007 04:59 AM
