Old 04-25-2009, 09:46 PM   #1
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
Interior center console switch cutouts?
Oay Im sorry for the crude Title, but there are same size cutout located next to where you switch the interior light dimmer (this is also one of them), or by your emergency brake. These appear to be a standard size idustry standard item, and I was wondering I would loked to utilize some of the blank ones with a lighted switch lite when on, for activating a low power item.
Is there a source that I can buy switched or other type items that are pop in replacement size wise to these? I could take the blank out and put a switch into it, but I think I would like to keep the blanks if I sell the car down the road, can anyone tell me what these are called or a source for replacements that have a custom application in mind?
Thanks, Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 05-21-2009, 12:50 PM   #2
N9QGS
N9QGS's Avatar
Im still looking for information on this?
198K Miles
Old 05-22-2009, 10:44 AM   #3
b_hickman11
Drives: 08 Sedan
Dude I can't understand your post.........
Old 05-22-2009, 11:49 AM   #4
in short, he wants a switch that fits right into the blanks by the handbrake.
and no, they do not seem industry standard. They are more like TOYOTA specific.
Old 06-25-2009, 10:55 AM   #5
N9QGS
N9QGS's Avatar
Thanks IllusionX for your comment, I could probably just order some blanks from toyota and drummel a switch into them, thanks so much. Ron
198K Miles
Old 06-25-2009, 11:03 AM   #6
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Yeah I've put things in those spots before. You can fit most standard switches in them with a little work. Good luck and post up what you do.
Old 06-25-2009, 11:08 AM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ thats what I did for the toggle for my aftermarket fogs, just take the blank out, cut out the size hole you need, and plug it back in.
Old 06-25-2009, 03:18 PM   #8
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
they had one at pepboys that fit almost perfect
its the large rocker style switch
http://www.4055design.com
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
