Old 04-26-2009, 03:19 PM   #1
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Question about painting Calipers and Drums
ok so im thinking of painting the calipers Red, should i leave the drums black or paint to match?
Second i noticed the calipers arent smooth, what would be the best way to smooth out? sanding/grinding down? can body filler be used?
Al always all suggestions appreciated
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 04-26-2009, 03:45 PM   #2
supmet
Drives: 2007 4 Door Yaris
I'd leave the drums black.. And just sand the calipers... body filler will fall off in about a day of heat and vibration
Old 04-27-2009, 01:07 PM   #3
1stToyota
1stToyota's Avatar
Even the special ceramic caliper paint might give you problems. Did all the prep work (to newly purchased calipers) and let it dry for days before put into use, still tended to chip easily and go soft if it made contact with brake fluid. Did this with one of my cars and had nothing but little headaches.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-27-2009, 01:09 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
ive been kicking this idea around myself lately. i just can't see red for the calipers and black for the drums though.....
Old 04-27-2009, 01:10 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i did a steele brush and then brush it off with regular brush and brush paint them..turn out great.. fire engine red!
Old 04-27-2009, 01:28 PM   #6
1stToyota
1stToyota's Avatar
Mine was a complete Krylon caliper prep and paint (brush) kit. Looked real sweet but had to do constant touch-ups. Maybe it was on the shelf too long, or they've improved them within the last 5 years.
2008 Scion xD
Old 04-27-2009, 01:36 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
i used plain old paint, not even high heat. lasted 3 years.
Old 04-27-2009, 01:39 PM   #8
BLAZINBLUEVITZ
^ you color match rear drum to caliper or ???
Old 04-27-2009, 01:40 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
hell no.
flat black rear drums
dark bronze front. matched my wheels at the time.
Old 04-27-2009, 01:52 PM   #10
at3GG
at3GG's Avatar
Drives: 07 metmet LB
kept mine drums black, have the calipers red as well. I didnt even sand mine. Just cleaned them VVVEERRYy well and sprayed (Krylon Caliper Paint) turned out great. About 2 months now and no chipping flaking or fade.
http://www.yarisworld.com/forums/sho...ally+good+pics
not great pictures but it will give you the idea of what red fronts with black rear looks like
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 04-27-2009, 01:53 PM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
use brake parts cleaner, best stuff for the job
Old 04-27-2009, 01:55 PM   #12
at3GG
at3GG's Avatar
yup...or a really strong degreaser, worked fine for me.
Tanabe Df210's
Old 04-27-2009, 02:15 PM   #13
I just did my calipers last Saturday. I would not go through the trouble of sanding them. You'll just drive yourself nuts for something which is only apparent when seeing them up close. My thinking is that the rough texture also provides added tooth for the paint to adhere to. I've got 6 coats of Dupli-Colour on. Now have to wait and see how durability holds out. Fingers crossed.
Only pic of them that I have at the moment.
