Old 09-10-2006, 12:05 AM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Removing Door Panels - Hatchback?
Anyone here have workbook instructions or can instruct me on how to remove the door panels on the liftback/hatchback?
TIA
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 09-10-2006, 12:32 AM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Easy, i was about to make one....but i couldnt be fucked......lol.....
Well this is a simple version of it. If you know a little bit about cars then this simple tutorial will be NP..
>Pull out the 3 grey long strips on the door
>If you have power windows, on the DRIVERS side the switches for the power windows will have 3 screws that will be attached to the grey plastic thing. Take them out
>So the 3 grey plastic things should all be deattached.
>Next there will be 3 black screws attached to the door panel.....take them out, one is in the middle and i forgot where the others are. But there are 3!
>time to pull it off! Pull the bottom part of the panel, and it will pop out. (Only the bottom half will pop out)
>Next is to PULL UP the door panel and the whole thing should come out.
Hope that helps
Old 09-10-2006, 03:23 AM   #3
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Because I don't want to start a new thread, what has to be done to change the front speakers?
Old 09-10-2006, 04:07 AM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Umm
THE PROPER WAY
>take out the wire plug thats connected to the stocked one...
>Get a DRILL and DRILL OUT the rivets that is rivetted on....(the silver things) theres 3
>get the "SAT6" bracket/spacer and attach ur 6.5" speaker onto it
>attach the wires to the new speakers to the wires onto the door. Negative with Negative and Positive with Positive.
>Time to screw the new speakers on, u can either screw it on or rivet gun it.
THE LAZY WAY
>take out plug which is connected to the stocked speakers
>LEAVE THE STOCKED BRACKET/SPACER in the door BUT RIP OUT the speaker (the middle part dont damage the stocked spacer)
>mount your new speakers on the spacer on the door, connect the wires, and screw in your speakers with screws to the stocked spacer.
Old 09-10-2006, 05:52 AM   #5
Katana
Katana's Avatar
Τhanks mate for the answer!
Always there for any questions!
Old 09-10-2006, 06:41 AM   #6
hasher22
Look mum no stars!!
hasher22's Avatar
U know what, u should do it the lazy way....i did it the lazy way and i have no probs!!!
Old 09-10-2006, 07:38 AM   #7
Katana
Katana's Avatar
The difficult way isn't more safe for damages?
Old 09-10-2006, 08:25 AM   #8
hasher22
Look mum no stars!!
hasher22's Avatar
haha i believe that both ways are the same....its just changing the spacer. the lazy way is just a really really cleaner and quicker way of doing it. I have dont it and i had no problems with it. Still going strong.
Old 09-10-2006, 09:34 AM   #9
Katana
Katana's Avatar
Ok thanks man!
Old 09-11-2006, 05:18 PM   #10
bigsky2
Cousin Vitz
bigsky2's Avatar
Thanks hasher!
Will post pics of my install when the time comes to give the visuals for the above instructions.
Old 09-11-2006, 05:36 PM   #11
hasher22
Look mum no stars!!
hasher22's Avatar
Ahh nice...though i already took pics for a tutorial....but i really couldnt be bothered uploadin it...ha
Old 09-11-2006, 07:29 PM   #12
bigsky2
Cousin Vitz
bigsky2's Avatar
Upload them mate!!!
Old 09-12-2006, 08:08 AM   #13
Katana
Katana's Avatar
Come on, we need one of your great tutorials!
Old 09-12-2006, 08:01 PM   #14
paultyler_82
What about the rear speakers, 5.25 speakers, right? do you need different spacers or will the SAT6's work back there too?
Old 09-13-2006, 07:32 AM   #15
hasher22
Look mum no stars!!
hasher22's Avatar
Katana...i seriously cant be bothered...lol
paul i was able to install the rear speakers......but they arnt install prop. I really dont know if the "sat6's" will fit in the rear...
Does anyone know if the sat6's will fit in the rear guys???
Old 08-21-2007, 05:43 PM   #16
YARmatey31
YARmatey31's Avatar
This might be a dumb/lazy question...but here goes...
which wire is positive and which one is negative. Is it in the manual or where/how did you find out? Thanks
YARmatey31 is offline   Reply With Quote
Old 08-30-2009, 10:38 AM   #17
mario98c
mario98c's Avatar
i need to destroy the speakers for remove them from the stock brackets???
Old 05-07-2010, 05:35 PM   #18
steverburton
Drives: 2007 Yaris
I can't get my hatch panel off to install an actuator. Does anyone know if there's a screw somewhere in it that I'm missing?? Thanks!
steverburton is offline   Reply With Quote
3 Door Hatchback Questions Dorkinheimer General Yaris / Vitz Discussion 12 01-16-2012 05:30 PM
Removing sedan mirror covers? Spades Cosmetic Modifications (Exterior/Interior) 6 01-12-2012 09:10 PM
Just Bought a 2009 Yaris Hatchback 4 Cyl Auto!! CASH DEAL!! Good Deal?????? paguy General Yaris / Vitz Discussion 13 05-28-2009 10:51 AM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
Yaris Hatchback Clearance Height Ryu General Yaris / Vitz Discussion 7 11-28-2006 01:35 AM
