Old 05-03-2009, 02:06 PM   #1
Deltasix
Deltasix's Avatar
Drives: '07 Liftback: Work in Progress
Send a message via AIM to Deltasix
Need help installing springs
Hey, quick question for anyone who might know. I'm installing progress springs on my '07 liftback, and am running into a bit of an issue.
After we get it all installed, the top is sitting really loose when we lower the car, resulting in a clunking sound whenever the car hits any sort of bump.
Any ideas?
"The basis of optimism is sheer terror."
Deltasix is offline   Reply With Quote
Old 05-03-2009, 02:13 PM   #2
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Top of what?
Are you talking about the front or back making the noise?
I think you didn't install them properly. The clunking sounds like the strut bearing, maybe.
Old 05-03-2009, 02:30 PM   #3
Deltasix
Deltasix's Avatar
Front.
Basically what it is is the part of that extends into the engine bay, its sitting too high up and knocking whenever any bump is hit.
It seems that we're not getting enough compression on the spring.
Old 05-03-2009, 02:41 PM   #4
earljail
earljail's Avatar
Did you install the spring with a spring compressor, or did you try to fudge it by lowering the car to compress the spring before tightening the bolt?
Old 05-03-2009, 03:12 PM   #5
Deltasix
Deltasix's Avatar
Spring compressor
Old 05-03-2009, 03:28 PM   #6
gwasabi
Drives: 07 Blazing Blue LB
Did you cut the bump stop? did you match up the grooves? sure the springs aren't upside down? try setting the car down and then tightening the bolts after the car is on the ground.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-03-2009, 03:36 PM   #7
Deltasix
Deltasix's Avatar
How can you tell what side is up? Pretty sure they're not.
Did cut the bump stop, and did match up the grooves.
Old 05-03-2009, 04:14 PM   #8
gwasabi
You can tell by the Logo. If the Logo is there. The part where the Coils are closer together is bottom I believe.
Serious Business...
Old 05-03-2009, 04:27 PM   #9
Deltasix
Deltasix's Avatar
Yeah, no they were in right
Old 05-03-2009, 04:29 PM   #10
gwasabi
Ok try lifting the car. Make sure the assemble is in all the way, tighten it all the way. Drop the car on the ground (Not literally) then tighten the bolt some more if its possible.
Serious Business...
Old 05-03-2009, 04:30 PM   #11
gwasabi
Like have someone hold the assembly up while you tighten the nut.
Serious Business...
Old 05-03-2009, 04:36 PM   #12
Deltasix
Deltasix's Avatar
Will try that, thanks for your help
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
