#1 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Home Built Bike Rack for Hatchback
I saw one on the net I liked so I went out back to the steel rack and started welding.
The arms were taken from an old bumper mount rack. I used 1" square tube, 1.25" square tube, 1/4" thick steel plate, 1" round tube, and $5 worth of new bolts. [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
NOT BAD at all but won't it rub on bumper while traveling?
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#3 |
MetalShark
The rub
It sure will. I need to weld on a travel stop and move the pin hole a bit.
#4 |
I love momentum.
Or coat just put a little bumper pad between the rod/bumper when you're using it.
#5 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
I was thinking about a little adapter with a cotter pin attached above the license plate holder to steady it.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#6 |
Great job. I love to see custom pieces for the Yaris.
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
awesome :D
-Jen <3 ![]() Quote:
#8 |
how much would it cost for another lovely custom rack :D
#9 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
Looks great!
| Bike rack for Yaris? | fmicle | DIY / Maintenance / Service | 51 | 09-20-2011 11:31 PM |
| Sedan - Trunk mounted bike rack | xtrred | General Yaris / Vitz Discussion | 7 | 06-27-2007 07:06 PM |
