Old 05-06-2009, 04:51 AM   #1
AlainMikli
AlainMikli's Avatar
DIY: NST SSK in MY09 LB
I just installed the NST SSK in MY09 LB with little modification. Pic showed that the shaved part of it to make it fit on my LB. Ppl are saying that some 09 Yaris might have different shift linkage than 07-08, I guess I might have the different one because I was following the other install thread and noticed it right away that it wouldn't sit right on top of it like the other one, something was in the way, I couldn't see the pin hole. If you compare the sliver plate(under the SSK) near the round rubber cap, it actually looks a bit bigger than the other one on the other SSK DIY thread, so shaving it a bit is a MUST!!
To do: Supercharger…
Old 11-23-2009, 04:54 AM   #2
datzlr
Drives: yaris
can u post pictures of your car ?
datzlr is offline   Reply With Quote
Old 04-01-2011, 09:17 PM   #3
swidd
Drives: Yaris HB
Did you remove the air box for this DIY?
Old 04-03-2011, 02:52 PM   #4
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yes, you can see from the last pic that there is no air box.
Check out my Build thread:
Old 04-04-2011, 11:07 AM   #5
kr1
Show & Go
kr1's Avatar
Drives: Yaris HSD -12, GT86 -12
Nice DIY
kr1 is offline   Reply With Quote
NST (NonStopTuning) Short Shift Kit Info, Specs, User Data... NonStopTuning Performance Modifications 195 12-23-2011 12:44 AM
NST SSK & New Wheels here :D Arkhangel Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-25-2009 07:42 PM
Question About NST SSK Arkhangel Performance Modifications 4 10-24-2008 11:55 PM
NST ssk OxyG3nE Items for Sale by private party 6 10-24-2008 06:22 PM
DIY - NST SSK (short shift kit) kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:12 PM
