Old 05-06-2009, 06:08 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Question for those with aFe intakes AND ScanGauges
Once your engine is nice and hot, how hot does your intake air temperature reading get when you sit and idle at a light?
The reason I ask is that I took off the metal heat shield off my aFe setup and get a noticeable rise in air temp every time I come to a prolonged stop. When the car is moving, the intake air temp drops quickly.
I don't remember if the original setup experienced a noticeable rise when the car was not moving.
Old 05-06-2009, 07:02 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Why would you take the heat shield off in the first place
Old 05-06-2009, 07:03 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Sounds to me like the heat shield is doing its job! Thanks for posting you findings.
Old 05-06-2009, 07:53 PM   #4
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
when the car's at a stop the heat stays in one place. when the car is running,
the wind is probably blowing away the heat. The heat shield is doing it's job
by blocking the heat coming mainly from the engine
808_Yaris is offline   Reply With Quote
Old 05-06-2009, 08:35 PM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i believe he took it off to fit an oil catch can.
Old 05-07-2009, 11:04 PM   #6
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
On my simota CAI I build up heat when in heavy traffic and and at stop lights too. Its sometimes raises by 15-20 degrees
