Old 05-10-2009, 02:20 PM   #1
keesue
Chillin' out by the Bay
keesue's Avatar
Oil temperatures
After seeing the post by JBIZZ: http://www.yarisworld.com/forums/showthread.php?t=17499 I thought it would be a great idea if those of you who have scanguages would post the min-max oil temps of the oil you are using. This would be valuable information on the efficacy of the cooling and friction reducing ability of brands/types of oil.
I found it interesting that Royal Purple did not reduce the op temp range of JBIZZ's engine. As operating temperature is the key indicator of lubrication, cooling and friction reduction, it makes one wonder how all the other oils compare.
What say ye?
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 05-10-2009, 04:46 PM   #2
OK Yaris
Drives: 2007 Liftback
The scangauge reads water temperature; not oil temperature. I'm not convinced it can be used to evaluate different oils. Too many variables.
Mike
OK Yaris is offline   Reply With Quote
Old 05-11-2009, 11:21 AM   #3
keesue
keesue's Avatar
Mike
Ah, ok. I thought it read oil temps. I was looking for min/max ranges. Thanks for the heads up on the Scanguage. If anyone has oil temp guages, I'd still be interested in this data.
Old 05-11-2009, 04:02 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Wouldn't gas mileage increase be a better indicator of efficiency? If you google, you'll probably find some studies or anecdotal stuff.
Old 05-11-2009, 04:55 PM   #5
keesue
keesue's Avatar
Yes, gas mileage is a good indicator, but I am more interested in the operating temps of oil in the Yaris engine; primarily the difference between 'dyno' oil and the various types of synthetic oils. I have data on other engines but in larger displacements., but, I'm more interested in the Yaris. I found it interesting that there wasn't a drop in op temp using Royal Purple.
I'd like to get more anecdotal data from Yaris drivers who have oil temp guages, and better yet, if they noticed a difference when switching to synthetic oil.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
embarrassingly bad mileage... REALLY XYaris Fuel Economy Forum 83 05-05-2009 04:47 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
