Old 05-15-2009, 02:19 AM   #1
regal
Header that fits the nitto midpipe
I want to go with the Nitto midpipes, is there a header that fits it without modification?
Old 05-15-2009, 03:22 AM   #2
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
Man, I'm not sure but I think most fit without modification. Weapon R's I believe need modifying. Megan or DC would be a good choice, IMO.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 05-15-2009, 09:13 AM   #3
mrbond
mrbond's Avatar
The Megan and DC have had fitment issues with the Nitto pipe as well. If you want to give it a try, go for a set of DME headers. Google search DME headers Yaris, and it'll be under the shopping thing. No clue if these fit the Nitto, but in my experience these were great headers to have. If all else fails, just go to an exhaust shop and have a midpipe custom made for you - that way you can also include a hi-flow cat and be able to pass emissions without having to swap the midpipes. Just my 2 cents.
- A Toyota Yaris
- A whut Yaris?
Old 05-15-2009, 09:27 AM   #4
For the one person who had to modify the midpipe, it was just a matter of grinding down the end a little -- then it fit perfectly. Otherwise, everyone who has tried it has had a successful install.
Old 05-15-2009, 09:36 AM   #5
mrbond
mrbond's Avatar
^ I read a couple of times that people had to grind down the flange on the headers? So, then would it matter either way - like either the header flange or the midpipe flange?
- A Toyota Yaris
- A whut Yaris?
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Nitto Midpipe w/ no muffler SweetRS Performance Modifications 12 05-12-2009 12:57 AM
Q about nitto midpipe? jaserhunter Performance Modifications 28 04-22-2009 02:28 PM
dc header and nitto midpipe.. mastaofdisasta Performance Modifications 3 04-17-2009 09:12 AM
