Old 05-18-2009, 11:58 PM   #1
Riced-yaris
Drives: 1998 EL, 2000 Civic, 2008 Yari
Weird Squeeking noise after lowering
Ok, so i finished lowering my Yaris at home 2 weeks ago. At low speeds, theres a lil squeek or when i take small turns in parking lots theres a squeek. I have made a few assumptions, I wonder if any1 else would agree:
1) Warped rotors - my friend suggested this, since its only low speeds
2) I installed the bumpstops wrong - I just slipped them onto the shock piston
3) The lil cushions that are on the coils of the Tein springs
4) The new angle of the lower ball joints
5) Possibly the rubber shock tower mounts maybe moving a bit at low speeds and they touch the strut towers
This lil noise is killing me. It bothers me, because my girl drives it and it annoys me b/c I cannot simply go to Toyota and bitch now, or else the warranty will be voided...
Riced-yaris is offline   Reply With Quote
Old 05-19-2009, 12:12 AM   #2
detroiter
detroiter's Avatar
Did you put the wrap around the springs? The stuff to help keep them from rubbing together?
Old 05-19-2009, 12:18 AM   #3
supmet
Drives: 2007 4 Door Yaris
Your warranty isn't voided, toyota would have to prove the parts installed caused the problem(which in this case would be pretty easy), but if you went in for a blown motor, they would still have to honor the warranty.
Warped rotors isn't it - you would feel vibration on heavy braking if they were warped.(With that said I can warp the stock rotors in a single trip to crestline(a little mountain town) and back if I'm not careful) I've warped the rotors 3 times on my yaris, and never heard them squeaking, just making lots of other bad noises.
I think the "lil cushions" on the springs are to cut down on noise, not make noise
Ball joints and strut towers doesn't sound right either, as tons of people on here have tein springs, and I haven't heard anything about either of these being a problem
Bump stops deal more with bottoming the springs out, rather than light turns, but if they are installed wrong, it could cause squeaking. Some people just remove the bump stops with aftermarket springs.
My best guess is you have new springs, and they make noise until they settle.
Old 05-19-2009, 12:19 AM   #4
Riced-yaris
Tein S-techs come with this piece of plastic wrapped around the spring. I left them on, cause I assumed that they were there to reduce noise, in the event the spring compresses to a point that the coils touch.
Old 05-19-2009, 12:19 AM   #5
YarisSedan
Drives: 08 Yaris Sedan
U need spring wraps the tightly coiled portion is rubbing together probally the rear mine do the same thing. One trick i did was rub brake caliber lub on the coils to they dont squeek and rub now.
Old 05-19-2009, 12:21 AM   #6
Riced-yaris
Your probably right...Its not the first time I have lowered a car. I usualy have more rationale thinking, but like I said, its my girls car...so its driving me nuts trying to figure out this noise.
I keep telling myself at times, that its the springs being new, which has caused the noise.
As for the warranty being voided, Toyota will say that I lowered my car, which made the suspension trouble. I can already imagine it...
Old 05-19-2009, 12:40 AM   #7
I have the Tein's, no noise. Can't think of what it would be either. And swap them out to the stock, and if there is still noise, bring her into the dealership. They'll never know.
Old 05-19-2009, 08:24 AM   #8
Riced-yaris
Sighh...did an alignment last week already. So its pretty much a waste, if I put the OEM springs back in. I would need to do 2 alignments now, just to bring it to the dealership to look at...would cost more. I'll have my mechanic take a look at it sometime this week...
Old 05-22-2009, 04:04 PM   #9
Riced-yaris
Arghhh...I HATE THIS CAR!!! The noise has gotten worse. My mechanic sprayed lithum grease on the shock towers. Noise went away for a a few minutes. He suggested that I take everything apart again and make sure the spring is sitting properly. I think it maybe the stupid plastic sleeve on the spring coils now...
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Transmission noise The little red pill General Yaris / Vitz Discussion 11 05-15-2009 01:26 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
