Old 05-23-2009, 10:25 PM   #1
jackrabbitnomore
Drives: 2007 Yaris S Sedan
Bridgestone Ecopia EP100 Tires
I just replaced the stock Potenzas that came on my 2007 S Sedan, 5speed. I only got 32k out of the tires, could have maybe gotten another 4-5k but was getting uncomfortable with bad rainy conditions in C. Florida lately. They were the crappiest tires ever. Anyway after searching the interwebs for LRR tires, I discovered this new tire from Bridgestone, the Ecopia EP100. They are designed as fuel efficient with the lowest RR of any tire made to date. (Less than .05 RRC)
I've only driven them about 200 miles, and won't have reliable FE numbers for a couple of weeks. But I can tell you already that they are going to make a huge difference. I can glide for a long time, with a lot less decay in speed from 55-60. Also I can tell my RPMs at different speeds are noticeably lower.
Oh, I should also say that I also went up one size from stock (185-60R15) to 195-65R15. They just barely fit, with about 1.5 inches from the fender wells outside, but there are no problems with rubbing. The increased height and overall size give the car a much beefier look, and the ride and handling are greatly improved, especially in wet, windy conditions and higher speed (75+)
I will update this post when I have some numbers. I have been averaging 37 overall, with no real effort and driving pretty much like a maniac. I know I can now break 40mpg with just a little effort.
jackrabbitnomore is offline   Reply With Quote
Old 05-24-2009, 02:01 AM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Check your speed...
...when your speedo reads 70mph, you're actually travelling at 73.65 mph.
http://www.carbibles.com/tyre_bible_pg2.html
aca72 is offline   Reply With Quote
Old 05-24-2009, 06:12 AM   #3
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
As your tires break-in, your mileage should go up some. It can take a few thousand miles for the tires to break-in. You might want to check your odometer vs a long highway section that is marked in miles. It will very likely show that you are under recording miles on the odometer, and that you need to adjust for the larger tires. I believe you made a good move in the tires. I am driving on Prius Tires, and they are great for mileage.
Good Luck!
roadrunner is offline   Reply With Quote
Old 05-29-2009, 05:48 PM   #4
Cosworth
Drives: S sedan
Wow, you went up 2 sizes!!! 185/60/15 --> 195/65/15! I was looking at the tirerack site and it doesn't seem like they have 195/60/15. :(
Could you comment more on your experience with the tires as time goes by? Especially on stability at highway speed & wet traction? Thanks!
I will probably go with 185/65/15 to minimize change in diameter, if I go w/ Ecopia.
Cosworth is offline   Reply With Quote
Old 05-30-2009, 09:31 PM   #5
jackrabbitnomore
Bridgestone Ecopia EP 100
So, far I couldn't be happier. They ride like a champ, and the extra height helps clear curbs and parking bumpers, whereas I used to scrape them occasionally. The car handles a lot better - cornering, braking, and more stable feeling at higher speeds.
Gas mileage on my first tank was 35.5 mpg. I was averaging 37, but haven't kept track too well since prices were down. Also, I haven't really tried too many HM techniques. I am starting to get back into DFCO, and cycling A/C off when I can. I haven't done ICE off in quite a while. Probably this summer if prices keep climbing, I will be doing all of the above.
Old 05-31-2009, 01:45 AM   #6
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
You realize anything that may have been saved with rolling resistance, has likely been regained in all that extra un-sprung weight, right?
firemachine69 is offline   Reply With Quote
Old 03-26-2010, 11:43 AM   #7
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
They have these tires in the stock size now for the Yaris Liftback from TireRack. They're summer LRR tires and placed second in the test TireRack conducted for fuel efficiency. Other factors were rated as well. http://www.tirerack.com/tires/tests/...y.jsp?ttid=121
KrazyDawg is offline   Reply With Quote
Old 03-26-2010, 12:15 PM   #8
interesting stuff....the aveo needs new all season tires....not as many options in 14" as id have hoped from that test...! only 1 tire in the top 3 for fuel efficiency has a 14" size...and at that theres only ONE size! 175-65-14
Old 03-26-2010, 12:25 PM   #9
127.0.0.1
you changed tires sizes ? throw all your comparison on MPG out the window
you changed the game entirely.
Old 03-26-2010, 12:29 PM   #10
well, he'll have to calculate mileage with the change in the odometer readings...
Old 03-26-2010, 06:51 PM   #11
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Exactly what I was thinking. The only way to get a REAL LIFE comparo in MPG from the "better RR" would be to have purchased the same size tires that you had before.
Yes you can maybe still compare, but lots of math will be involved.
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 03-27-2010, 12:30 AM   #12
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Wish they had them in 185/60/15 (assuming they wear down slower than the Potenza's). I could use a normal MPG again as a DD once I get R-comps for the track
bridgestone, mpg, oversize tires, rolling resistance, tires
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Does anyone here know why Bridgestone tires are so expensive? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-03-2007 11:10 PM
