Old 05-25-2009, 02:34 PM   #1
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Fujita F5 noise/rubbing
I recently installed the Fujita intake for the Vitz last Friday. Install was a pain in the ass, but got it done. No CEL was thrown on me.
Problem: Rubbing noise on left drivers side when turning wheels left and right on a sharp turn. Also starting off, i can feel vibration from the filter or around there. The vibration damper that came with the intake is tightly fastened on.
Any solutions or suggestions would be helpful.
Thanks in advance~
Old 05-25-2009, 02:40 PM   #2
More offset on different rims?
Old 05-25-2009, 02:58 PM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Forgot this information....
Wheel/tire setup - Enkei RS7 17s
205/40/17s
42mm offset
Anyway way to eliminate rubbing or vibration noise w/o going 16s....?
Old 05-25-2009, 05:33 PM   #4
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
had the same problem with fujita cai..is it a metal to metal sound?..twisting the tube till u find the sweet right spot should solve it, i believe the tube is hitting a metal part of ur car....
Old 05-25-2009, 09:13 PM   #5
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Yes, its a metal to metal sound, it can be heard inside the cabin when starting off, reversing, etc.
I'll twist the tube a bit, but it wont twist much because when i tighten the vibrator adapter down, it moves to default position.
I took out the bumper, to see if filter was rubbing against the front bumper. But thats fine.
Did you tighten the vibrator adapter down all the way Malaya?
Going for a test run~
Old 05-25-2009, 10:08 PM   #6
mrbond
mrbond's Avatar
Well, first I'd recommend loosening the bolt in the rubber vibration damper. If that doesn't work, alter how much pipe is going into the actual filter, since there's a bit of room play in that area where the filter is. If all else fails, buy an engine damper from microimage :P
- A Toyota Yaris
- A whut Yaris?
Old 05-26-2009, 03:27 AM   #7
Malaya1221
Malaya1221's Avatar
like mr bond said....loosen the bolt first then try to twist the tube then tighten the adapter down...believe there is a rubber on that adapter, not 100% sure...have to check mine tomorrow...
Old 06-02-2009, 04:25 PM   #8
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Internet was down, so i loosened the hose clamp and tugged it away from the car's metal piece it was clinking on. Now it doesnt make any noise when starting off, aside from the growl/roar.
Thanks Malaya & mrbond for the help ^_^
Maylaya: Did you take out the fog light cover for more efficient cooling to pass through the filter on your intake? Thats what i have done, but thinkin of putting mesh of some sort~
Old 06-02-2009, 10:31 PM   #9
Malaya1221
Malaya1221's Avatar
nope, don't think it will make that much of a difference...if you try it, take some pix...have fun!
Old 06-02-2009, 10:34 PM   #10
mrbond
mrbond's Avatar
That's what I've done, actually. I kept the factory fog light cover, dremelled it out so that there are still those two horizontal bars. I actually noticed a slight difference in acceleration and throttle response. Because think: ambient air is going straight to the filter, rather than getting warmer air from the engine bay. I say do it.
- A Toyota Yaris
- A whut Yaris?
FS: WR Dragon SRI...cut down w/ Fujita filter jkuchta Items for Sale by private party 9 02-26-2009 12:03 AM
Cleaning the Fujita intake filter KSIbucky DIY / Maintenance / Service 0 02-25-2009 07:40 PM
Problems with my fujita... Blenjar Performance Modifications 9 09-18-2007 03:11 PM
fujita picture KSIbucky Photo-Video-Media Gallery 3 09-17-2007 01:28 AM
Fujita Cold Air Intake iheartmyyaris Performance Modifications 14 02-10-2007 01:03 PM
