Old 05-26-2009, 03:40 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Head unit mounting screw. Fell behind HU!
Ok so I was removing my HU and in the process, I dropped one of the mounting screws behind the HU somewhere. Looked in and saw the screw suspended in mid air by some of the wires in the HU harness. Reached in to grab it and it fell. Heard a clank and it was gone from sight. Is it gone forever or will it fall out of the bottom of the car somewhere?
This is one of the eight screws that mounted the HU to the mounting brackets (four on each side).
Old 05-26-2009, 04:51 AM   #2
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
find a replacement screw at your hardware store, or my little trick is use a magnet haha :)
808_Yaris is offline   Reply With Quote
Old 05-26-2009, 05:09 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
The problem is, I can't see where it is anymore. It fell to the bottom of the interior of the car below the back of the HU area.
Old 05-26-2009, 05:25 AM   #4
808_Yaris
Where is Oahu?
808_Yaris's Avatar
i think it would be better to get a replacement screw then :)
Old 05-26-2009, 05:55 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
Having that screw to use isn't the issue. I just don't want to have a screw rolling around the metal at the bottom interior of my car.
Old 05-26-2009, 08:17 AM   #6
808_Yaris
Where is Oahu?
808_Yaris's Avatar
find it! haha if you don't want to take anything apart, i'd recommend a flat magnet connected to a string, and go fishing!
Old 05-26-2009, 08:23 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Is it stuck down there or will it eventually fall out somewhere?
Old 05-26-2009, 08:24 AM   #8
808_Yaris
Where is Oahu?
808_Yaris's Avatar
not suree. but in my opinion, i think it would still be stuck down there.
Old 05-26-2009, 09:24 AM   #9
haha i had this happen when i had the echo. It also happened with my yaris.
The echo's, i heard it fall on metal, so i knew i would not find it again unless i remove the whole interior and the carpet. So i said fux it, and left it there.
My yaris, the screw fell and was suspended mid-air in the wires. Same thing happened when i tried to reach, and it fell down. Hey! I found it on the carpet after a while :P
anyways, you are likely never gonna hear it rolling around the bottom of your car.
Old 05-26-2009, 08:41 PM   #10
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if you took apart your console you'd prolly be able to fetch it... that'd be a pain in the butt to take apart just for screw. SO... get a replacement UNLESS you have an annoying rattle because of the screw... in that case i'd say go for it.
Old 05-26-2009, 09:40 PM   #11
eggyolk808
Drives: White S Sedan
lol. i had the same thing happen to me! i dropped it but didnt think it was worth looking for. Nothing rattles and my HU stays in place with 3 screws, so its all good :-)
eggyolk808 is offline   Reply With Quote
Old 05-28-2009, 12:59 AM   #12
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
you can pull out the ac/fan control section and probably get a better view of the floor there
Old 05-28-2009, 01:50 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I just tore apart my dash today...It's not that difficult to get behind there. I have pics...
― Thomas Paine
Fitting amplifier to Yaris head unit nish1979 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2009 06:18 AM
Head Unit Mounting keesue In Car Entertainment + Electronics (audio / video / alarm) 6 03-17-2009 10:02 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
