Old 05-27-2009, 07:41 AM   #1
Ferret_san
Hack.... What hack ??
Ferret_san's Avatar
Drives: 07 YR
Basic Electronics Help Needed !!
Hi Guys. Hoping someone here with some basic electronics knowledge can
help me out. My nephew is doing a class project and wants to make a simple
working traffic light.
Because I have a very limited understanding of electronics <cough> none
<cough> I'm hoping someone can show me the wiring diagram that I'd need
to put together.
Basic plan is to use 3 flash light bulbs and hook them up to a simple 3
way slide switch and battery pack (2 AA batteries or 9 volt ?),so the left
position illuminates the red light, the middle illuminates yellow, and the
right position illuminates the green.
A further on/off switch will also be included for the power.
Anybody feeling generous that can help me out with the wiring ?
Nothing fancy, just something simple enough for him to explain how it works,
and how it was wired.
Ferret_san is offline   Reply With Quote
Old 05-27-2009, 08:59 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
here's a ladder logic wiring diagram
Old 05-27-2009, 09:03 AM   #3
highwaypass
Captain Slow
Drives: '08 1.5 hatchback
i forgot how to do it,but once i made it on my junior high school project.
Why don't your nephew just buy the knock down one?
highwaypass is offline   Reply With Quote
Old 05-27-2009, 09:15 AM   #4
highwaypass
Captain Slow
hope this will help you.
CMIIW
Old 05-29-2009, 11:09 PM   #5
Ferret_san
Ferret_san's Avatar
Drives: 07 YR
Sorry Tamago, I can't really translate the ladder logic diagram.
Any chance you could simplify it on the diagram I posted ?
And unfortunately, the 2nd on/off switch is a necessary evil I'm afraid.
Old 05-30-2009, 12:15 AM   #6
Here you go:
Old 05-30-2009, 06:29 AM   #7
Ferret_san
Ferret_san's Avatar
Drives: 07 YR
Here you go:
You're a good man. Thank you sir !
Old 05-30-2009, 10:51 AM   #8
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Get your nephew some extra brownie points for creativity and run it off solar power.
Old 05-30-2009, 10:53 AM   #9
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
FYI, you're going to need a resistor with those LEDs.
firemachine69 is offline   Reply With Quote
Old 05-30-2009, 11:28 AM   #10
GeneW
Drives: 2008 Yaris
Here you go:
Attachment 24520
I think 390 ohms is a bit light, no pun intended, with an LED and a 9 volt source. I've seen about two to three volt drops on average with an LED, which gives you from 15mA to 18mA current with a nine volt battery and 390 ohm resistor. That's a wee bit high for an LED. You can do it but they get hot and won't last long. Also drains the battery faster.
Keeping that current around ten mA would run the LEDs cooler... I'd recommend a 560ohm resistor, which would give you a more gentle 11mA to 12.5mA range, assuming a 3 to 2 volt drop across the LED.
I used to use 470ohm resistors with 5 volt sources and LEDs... I like to keep things on the low to middlin end to preserve function and reduce heat on working parts.
Gene
PS
If someone can scan in the LED's spec sheet we can do a better job of calculating a good current limiting resistor for this project.
Old 05-30-2009, 08:56 PM   #11
5mm axial lead LEDs are rated for 20mA or greater.
Red: forward voltage = 2.2V, forward current = 30mA
Green: forward voltage = 3.5V, forward current = 25mA
Yellow: forward voltage = 2.0V, forward current = 30mA
The 390 ohm resistors are fine for all three LEDs.
Old 05-30-2009, 09:14 PM   #12
GeneW
Drives: 2008 Yaris
Typical or Absolute maximum ratings?
Gene
Old 05-30-2009, 09:17 PM   #13
Gene
Typical. Absolute max is 100mA for all.
Old 05-30-2009, 09:35 PM   #14
GeneW
Drives: 2008 Yaris
Don't buy it. I've seen Max If as low as 50mA and even 30mA for some LEDs. Depends upon the manufacturer, lead heat conductivity and other factors.
I think we could both agree that whoever is building this thing better take a moment to read the If figures on the cut sheet. If not they could experience untoward failures.
Been there, done that....
Gene
What is needed for coilovers justinparadise21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 01-03-2009 12:53 AM
Who Bought the Basic Model and How Much? yarisugi New YARIS Purchase Forum 36 12-30-2008 12:17 PM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 02:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
