Old 05-27-2009, 03:26 PM   #1
halli09
Drives: 96 honda civic
how is the manual transmission
hey i was just wondering how the manual transmission was in the 09 yaris. is it pretty solid or would you recommend the automatic?
halli09 is offline   Reply With Quote
Old 05-27-2009, 03:29 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
can you drive the car like a normal person and not try to racerboy bang the gears everywhere you go?
yes?
then the 5spd is for you :)
Old 05-27-2009, 03:34 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
lol @ above.
i love the yaris trans. its super smooth and even better with the nst ssk!
Old 05-27-2009, 03:36 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
it does suffer heavily from weak synchros however.
Old 05-27-2009, 03:48 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I wouldn't buy a Yaris (or any other car for that matter)that wasn't manual. Auto trans robs too much power for the tiny Yaris engine.
Old 05-27-2009, 04:02 PM   #6
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
A little four needs a manual transmission. An automatic robs the car of horsepower and with a manual you are able to select what gearing you are using by means of human intelligence as opposed to a box of hydralic fluid.
Bob Dog is offline   Reply With Quote
Old 05-27-2009, 04:19 PM   #7
transcendentalcrap
Drives: 2007 Yaris 3d manual
Send a message via MSN to transcendentalcrap
one opinion . . .
I've driven both in LB form and am split.
The manual is better if you not the aforementioned racer-boy-wanna-be but suffers from quirky shifting when it's cold out and the auto choke is revving high.
The automatic is geared to have comprable acceleration where it counts 55mph to 75mph but is not quite as useful for obvious reasons. The automatic does suffer, imho, in the lower mph range; in town range might be an accurate characterization (20mph to 45mph).
For what its worth I did buy the manual.
transcendentalcrap is offline   Reply With Quote
Old 05-27-2009, 05:21 PM   #8
Goose
Car Geek
Drives: Yaris Liftback
I've owned both auto and manual versions of the Yaris. Both trannys are very well designed and smooth. I would let the kind of driving you do determine which you get, since both transmissions perform very well.
Kevin
'07 Blazing Blue 5-speed liftback (sold)
'08 Black auto liftback (sold)
'09 Carmine Red auto 4-door liftback (sold)
Goose is offline   Reply With Quote
Old 05-27-2009, 05:21 PM   #9
yarismaris
Drives: yaris
I ahve 07 Yaris with manual. Stock, it was not bad. I changed out the stock oil with Red Line synthetic, and now it is smooth as glass and a joy to drive. No more reverse clunk either. You will find that lots of people on this forum made that same switch.
yarismaris is offline   Reply With Quote
Old 05-27-2009, 05:29 PM   #10
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
My car has a simple short shift that was put right on top of the transmision. One small clip to remove, plop the new part in reclip and done. Makes it a different car and a real fun. I'll be getting NST bushings to make it even better. Best car for the money I have ever owned.!
Lazerdot is offline   Reply With Quote
Old 05-27-2009, 07:54 PM   #11
cdavidhess
cdavidhess's Avatar
Drives: 2008 White Yaris Sedan 5 speed
The manual is smooth and easy to use. Like any manual transmission, it may take a little time to get used to its "feel."
cdavidhess is offline   Reply With Quote
Old 05-27-2009, 11:24 PM   #12
texkid
The one with cheese on it
Drives: '10 Corolla S
Believe it or not, the manual tranny is pretty strong. A 4-banger always rocks with a manual tranny
texkid is offline   Reply With Quote
Old 05-27-2009, 11:34 PM   #13
MadMax
MadMax's Avatar
Well, I guess I'll give the other side of the coin...
Get the auto. The gas mileage rating isn't that much different, and if you are ever stuck in traffic, having a manual sucks! Plus, as I've said before, you can always manual shift the auto, but you can't auto shift the manual!
When I was searching for my Yaris, the autos outnumbered the manuals by a factor of something like 7:1. I believe Toyota sent a considerable number of more autos over, mainly because the gas mileage wasn't that different and the manual transmission and/or clutch is a bit rough (see the earlier synchros comment). It is still a lively car with the auto, and much more relaxing to drive when you need it to be.
And the torque converters on autos can be quite beneficial in certain circumstances!
Old 05-28-2009, 12:55 AM   #14
Morgan
Morgan's Avatar
Drives: 07 MM LB
I'm curious to see how the new transmission holds up... [I bought my 07 used with 5k miles and at 29k miles my third gear synchro made it almost impossible to shift to 3rd without a loud metal grinding sound; Toyota replaced the transmission with a transmission from a 09 model and so far so good]
I had an xA auto and thats the reason I switched to the yaris, the auto was a little boring for me, but to each his own - just depends on what you want! GL
Old 05-28-2009, 07:17 AM   #15
Originally Posted by echo_hrs View Post
Yaris 5 speed + TRD Quickshift + NST Quickshift 2nd Stage + TWM Aluminum Shifter Cage Bushings + NST Aluminum Shift Cable Bushings = Pure Awesome...
Cheers
+1
Nothing like the satisfying "clunk" of the lever smoothly falling into position as if on rails
Personally I would not want an auto transmission in the Yaris. Sure, I live in a city well known for its traffic jams and it's a real pain in the leg () sometimes, but you get used to it, a small price to pay...
Old 05-28-2009, 07:22 AM   #16
JBougie
JBougie's Avatar
Hmm .... I am due for a tranny flush here in about 10k and I think I'll be switching up the fluid type - I have noticed that the gears really do grind more often than I'm OK with, and I hate the reverse thud noise. But seriously, the grinding could very well be from driving with heels :) It happens like once every couple months (it's not a daily thing by any means)
All and all I love the tranny, I didn't expect to get to 42k and have no issues (I have an 07 that I bought right off the showroom floor) so I am *super* happy with it :)
JBougie is offline   Reply With Quote
Old 05-28-2009, 07:23 AM   #17
JBougie
JBougie's Avatar
+1
+1 on that - traffic is the worst part, but my calves are in awesome shape so I can't complain lol
Old 05-28-2009, 07:37 AM   #18
Funny thing is, after along stint in traffic, once I get out of the car, my right leg actually hurts quite a bit more than the left!
Is this ruining my Manual transmission? Syroyizhka General Yaris / Vitz Discussion 3 04-03-2009 11:24 AM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
Manual Transmission woes thatboyjer General Yaris / Vitz Discussion 24 07-30-2007 07:46 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
JDM Center Console Box + Manual Transmission bigsky2 Cosmetic Modifications (Exterior/Interior) 5 11-28-2006 08:08 AM
