Old 05-30-2009, 02:32 PM   #1
naossoan
Drives: 07 Yaris 3DR
So this is bad, right?
So before I left for work this morning, I decided to check the tops of the shocks to make sure everything was still tight.
I installed the springs at a friends house with a garage 2 hours away and drove home on the highway afterward. I'm assuming they were probably like this the whole drive home.
Is this why the instructions said not to use the same nut from disassembling the shocks to put the new springs on? But I did anyways because I didn't have any other nuts to use...
Do I have to re-do the front end and tighten up that nut?
naossoan is offline   Reply With Quote
Old 05-30-2009, 03:58 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
this gap has been present on all the aftermarket installs that I have seen on here.
I do not believe it matters, however wait before someone more knowledgeable on springs chimes in before you take my advice.
Old 05-30-2009, 04:28 PM   #3
ddongbap
Damn yo, thats a pretty decent camera. I can't take closeup-anything with mine.
Old 05-30-2009, 04:41 PM   #4
1NZYaris1
1NZYaris1's Avatar
Jack the car up , till the front wheels are off the ground ,
if the gap disappear's then yes you have a problem.
Old 05-30-2009, 04:45 PM   #5
naossoan
Hey thanks.
It's a Canon SD1100IS 8 MP pocket/point and shoot camera. It was $199 when I bought it, it's a bit cheaper now I think. It's a pretty decent little camera, yep.
As for the gaps, anyone else have a suggestion?
Thanks!
EDIT: Ah I didn't see the above reply before I replied. I am at work but I will try that when I get home..I don't have a jack other than the one included with the car from Toyota. I can just lift up one side at a time, yea?
Old 05-30-2009, 05:00 PM   #6
1NZYaris1
1NZYaris1's Avatar
Originally Posted by naossoan View Post
Hey thanks.
Thanks!
just lifting up one side is Ok ,
Old 05-30-2009, 05:01 PM   #7
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
we had 2 old threads before the hack and i believe that all of us that lowered the car have that gap!
Old 05-30-2009, 05:11 PM   #8
1NZYaris1
1NZYaris1's Avatar
No gap on mine
Old 05-30-2009, 05:14 PM   #9
Malaya1221
Malaya1221's Avatar
hmm...1nz, did u cut the bumpstops?
Old 05-30-2009, 05:14 PM   #10
naossoan
OK that sounds reassuring. On the drive home everything *felt* normal. Handling was great too.
I'll try what 1NZYaris1 suggested, see if the gap is gone when i take the weight off the shock. I remember when I still had the car up on car jacks after I put the shocks in, there was no gap then. I can't recall if I saw it when I put the car on the ground while I was putting in all the stupid black air ducting crap as I wasn't really looking at the shock caps.
When I cut the bump stops, I did them according to what TEIN's instructions said, or at least how I interpreted them. IT said to cut them in manner "A" which was to remove some from the bottom, 1.4 inches. I wasn't sure if they meant the bump stop swere to be 1.4 inches total, or to cut 1.4 inches off. But I marked a line at 1.4 inches from the bottom and started hacking away. I read that it's important not to cut the bump stops too much or you will bottom out the chocks during sharp/fast corners or hitting large bumps at speed, so I figured it was safer to go with the 1.4 cut off...as it wasn't quite half of the whole bump stop.
Old 05-30-2009, 05:17 PM   #11
Malaya1221
Malaya1221's Avatar
1nz, your pic here from ur garage has that gap...did u solve it? how?...btw, clean engine bay...
Old 05-30-2009, 06:20 PM   #12
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I've seen several lowered Yari with that gap, including mine...
Old 05-30-2009, 06:23 PM   #13
1NZYaris1
1NZYaris1's Avatar
No that, photo is a little miss leading , that was taken on stock suspension
and the dimples where touching .
I will double check mine when it get's home next week, it's gone on
a road trip arround the South island.
Old 05-30-2009, 06:31 PM   #14
CtrlAltDefeat
I ♥ Yaris
just took a picture of my dirty dirty engine bay
Old 05-30-2009, 06:45 PM   #15
naossoan
Interesting, so maybe I didn't need to waste my energy biking to work this morning! LOL!
I need the exercise anyways.
Any idea why this happens? I don't really understand why the top would be pushed up like that.
Old 05-30-2009, 06:50 PM   #16
CtrlAltDefeat
I ♥ Yaris
I don't know, but I bet when you hit a bump on stock springs it goes up like that. With the shorter springs, it's like there's a pre-load of sorts on the shocks. At least thats my guess...
Old 05-30-2009, 08:12 PM   #17
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I've got a bit of a gap at the top of my shock towers, too.
Old 05-30-2009, 11:56 PM   #18
detroiter
detroiter's Avatar
I have a tiny bit, but hardly anything like the last picture up above. My gap is very minute. I'd say it's just the nature of the lowering beast.
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
Anyone have bad "orange peel" on their stock paint? jdium Wash, Wax, Detailing, Exterior Repairs 30 08-05-2007 08:00 PM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
