Old 05-31-2009, 03:35 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
1ZZ Throttle+Bomz intake=Power!
I installed the throttle body I got from Garm. Instead of the stock intake, I used a Bomz intake - I just could note get the stock rubber intake tube over the new throttle body. The Bomz silcone intake adapter was a breeze. Install was not very hard at all - just a pain in the ass to get to the wheel well to get the filter on. While I was down there, I decided to pop out the black plastic insert where the fog light goes just to see if a bit more cold air will make a difference.
Wow! Power/torque in the whole PM range with the most prominent gain in the mid and upper ranges. I had only a bit of mild oscillation on the initial start up and no problems since. For the price, this is a MUST mod.
Interestingly my exhaust sounds louder. It is not coming from the front as I expected.
Just make sure you follow all the instructions on the website, gasket sealer is a good idea, disconnect the battery for a while(only did mine for 30 min and left the light switch on)
I will modify the L foglight plastic insert into something more cosmetically pleasing. I will also change the silicon to black and paint the intake tube flat black.
:burnrubbe r:
fuji is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
1ZZ throttle - Not Optimized Yet! fuji Performance Modifications 30 06-04-2009 12:40 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
