Old 06-05-2009, 12:47 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
DIY for Bi-Xenon?
Does anyone have/know of a DIY for the Xenon-Vision bi-xenon headlights? Their included instructions only shows regular HID install, not the bi-xenon and I'm totally confused.
MGargano is offline   Reply With Quote
Old 06-05-2009, 02:01 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im curious as well. this reverse grounding is confusing..as far as i know power is always on and the accesories is the one being turned off..drl makes this more complicated.
Old 06-05-2009, 02:50 PM   #3
DerFlosser
DerFlosser's Avatar
I don't but I believe that, as a registered vendor, xenon-vision should have to supply a DIY online or specific installation instructions for all of the Yaris offerings. Just my .02 on the subject but...I am sorry that I can't help. I understand that model years, DRL's etc. complicate things but how can you sell something that you cannot adequately support or answer questions on. Having a centralized location with all of the information for a standard H4 vs. bi-xenon (including all model years) is a win-win for everybody.
DerFlosser is offline   Reply With Quote
Old 06-05-2009, 04:02 PM   #4
MGargano
It's all good, I got it figured out. I was just having a retard moment, but everything's working perfectly. No DRL issues and fog lights work 100%
Old 06-05-2009, 04:29 PM   #5
marcus
toyota
marcus's Avatar
so how did you run the hid with drl ..
Old 06-05-2009, 10:36 PM   #6
MGargano
Sorry, I should have been clearer. With the bi-xenons, you don't have to do any DRL modification. The kit truly is plug & play and there's no need to disable/unplug the DRL, which allows the fog lights to still work. Perfect!
Old 06-06-2009, 09:56 AM   #7
marcus
toyota
marcus's Avatar
seriously..wow..what kit do you have..the ballast maybe be compensating for the 10v for drl unless ur high beam is the hid bulb and low beam wire running the regular bulb.
Old 06-06-2009, 11:19 AM   #8
MGargano
I have the 6000K bi-xenon kit from Xenon-Vision. The DRL simply doesn't work anymore, but didn't require me to disable anything. I guess something about the bi-xenon kit disables the DRL on its own. All I know is that it's working perfectly and I couldn't be happier.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
