Old 06-05-2009, 11:22 PM   #1
regal
Bottoming out while heavy breaking/turning
I had gone over a curb, they replced everything from th oil pan to the xmember to the entire exhaust.
I'm on TRD springs, Tokico Blue hock, TRD reaer Sway.
Under very fast heavy braking I sometimes feel something like the tranny bottoming out/grinding. Toyota dealer offered to look at it but they just usually baby drive. Do you thik I am just pushing the limits of the TRD springs?
Its really not repeatable, only happens under the worst abuse, do you thik it is worth a trip back to the colllision center?
Old 06-05-2009, 11:32 PM   #2
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
time for a stiffer setup? :)
taKuto is offline   Reply With Quote
Old 06-05-2009, 11:55 PM   #3
auxmike
auxmike's Avatar
Time to stop abusing a Yaris??
Old 06-06-2009, 06:23 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
what's your tire air pressure, and how much did you cut off your bump stops when you installed the suspension?
Old 06-06-2009, 09:09 AM   #5
SailDesign
Drives: .
Or are you confusing the "sandpaper" feel of the ABS with something bottoming out.
But Yeah - tire pressures?
Old 06-06-2009, 09:27 AM   #6
kngrsll
Apexing Egg!!
kngrsll's Avatar
try smoothing out your driving style, remember SMOOTH = FAST
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-06-2009, 09:58 AM   #7
regal
You know I've ever owned an ABS veicle, this maybe it. It is like a sandpaper grabbing and releasing quickly.
Old 06-06-2009, 10:01 AM   #8
regal
Cars are built for us to drive hard. I have owned 12 cars in 20 years and enjoyed pushing their limits. Only car I couldnt kill was an eg civic
Old 06-06-2009, 05:22 PM   #9
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
There you go! it's probably the abs doing its thing.
Go find some slippery surface and do some heavy braking to try to replicate the feeling.
Old 06-06-2009, 08:48 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
answer my question please
Old 06-08-2009, 10:38 AM   #11
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
sounds like abs, you might be able to easily deactivate it for your hard driving days...
Old 06-08-2009, 10:53 AM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
not recommended... you'll be HATING life.. instant brake lockup
Old 06-08-2009, 12:40 PM   #13
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It is definately NOT instant lock up, The car is fine without it. You just have to be smooth on the brakes and modulate the pedal.
Old 06-08-2009, 12:42 PM   #14
largeorangefont
Break'em off some.
Tamago is right, you could be on the bump stops. My car never exibits this behavior and I am lower than you are.
Old 06-08-2009, 01:08 PM   #15
markitect
Mine has no abs and the only time I lock up the brakes is when I'm being an idiot.
Another thing to check is the plastic inner-fender liner. I had a similar problem and it turns out I was rubbing on it (with stock wheels and tires) because it had popped in. I just pushed on it to pop it back into place. Mine was never in an accident or anything, I assume its from autocorssing.
markitect is offline   Reply With Quote
Old 06-08-2009, 01:10 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
have you driven an abs equipped toyota with the relay removed? the brake booster is especially touchy on abs equipped models.
Old 06-08-2009, 01:15 PM   #17
kngrsll
Apexing Egg!!
kngrsll's Avatar
there is a difference between having no ABS and having ABS disabled though...
Old 06-08-2009, 02:43 PM   #18
largeorangefont
Break'em off some.
Yes and Subarus as well. Like I said.. you just have to be smooth. I've only done it on the track though, not on the street.
Yes if you start stabbing at the brake pedal, you are going to lock the wheels.
rubbing up front under heavy breaking regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-12-2009 12:23 PM
heavy braking regal General Yaris / Vitz Discussion 8 05-12-2009 11:45 AM
ACT Clutch Kit 2007+ Toyota Yaris Heavy Duty 6 Puck trini_per4mance Items for Sale by private party 0 12-20-2008 12:16 AM
A little Culture (heavy on the bandwidth) GeneW Off-topic / Other Cars / Everything else Discussions 0 11-21-2008 04:50 AM
How Heavy is the flywheel? jouslee DIY / Maintenance / Service 12 02-22-2007 02:18 PM
