Old 06-12-2009, 11:53 PM   #1
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
Help me choose a rim size please
http://jhpusa.com/store/pc/viewPrd.a...idproduct=2019
15' or 16' ? Either way im goign to run Falken 195' tires. And im gunna be dropping my sedan on D2 Coil overs, just wanna know which size you guys think will look better..
id3379 is offline   Reply With Quote
Old 06-13-2009, 12:05 AM   #2
Brian
Brian's Avatar
16's
Old 06-13-2009, 02:03 AM   #3
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
16's will look better, 15's perform better.
bdc87 is offline   Reply With Quote
Old 06-13-2009, 03:20 AM   #4
I'd get 16's, but if there's a HUGE difference in weight, then go with 15's. It also depends on the offset, I think, since you'll be lowered on coilovers.
Kimona is the wheel expert, so I'd wait for him to chime in.
Old 06-13-2009, 06:54 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
15x6.5, ET40 or 16x7, ET40? Both will work very well with 195mm tyres and coilovers.
Which size "will look better"?... 16's with 195/50's.
Old 06-13-2009, 09:30 AM   #6
SailDesign
Drives: .
I'll go 16 as well, having had them on the old Yar. Just right.
Old 06-13-2009, 10:51 AM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
I say 16s cause they are wider.
Its a Chao!!!
Old 06-13-2009, 11:13 AM   #8
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
16" with 195/50 is basically a 15" with 185/60 (stock); and probably one of the better choices. are you going to autocross? I'd def. go smaller than 16" if so
Old 06-13-2009, 11:50 AM   #9
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
These Spun rims are going to be used for Daily Driving
I'm going to buy separate forged rim/tires for track use.
Old 06-13-2009, 12:01 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
get the 16's then.
Old 06-13-2009, 09:50 PM   #11
Kal-El
Kal-El's Avatar
16's for sure.
I've been debating with myself on what size to get except my problem has been..."16's or 17's?"
I'm pretty much decided on 16's because I need to maintain a good balance of looks and practicality.
what size rim do you prefer? thebarber Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 05-04-2009 12:09 AM
rim size joeharth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-09-2009 02:09 PM
rim size phenoyz Fuel Economy Forum 7 02-10-2009 02:11 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 03:20 PM
