Old 06-16-2009, 09:50 AM   #1
nimith
Drives: 2007 yaris hatch
TSB #0344-08
Twice in the last two weeks my car has shut down. Engine light came on and the scan codes were P0121 and P0223. My car has 45,000 miles and the diagonostic check found failure in the engine wire harness. With-out any fight Toyota is installing all new parts at no charge. They told me if I had to pay it would be $800. They also told me this is becoming a big problem, thats why it is being done at no charge. Just thought i would share the info!
nimith is offline   Reply With Quote
Old 06-16-2009, 02:04 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
you are receiving an upgraded engine wiring harness... that is why it would be some money...
here is the list of DTC's that are related to this
• P0101 – Mass Air Flow Circuit Range / Performance Problem
• P0102 – Mass Air Flow Circuit Low Input
• P0103 – Mass Air Flow Circuit High Input
• P0121 – Throttle / Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
• P0125 – Insufficient Coolant Temperature for Closed Loop Fuel Control
• P0172 – System Too Rich
• P035# – Ignition Coil “#” Primary / Secondary Circuit
• P2237 – Oxygen (A/F) Sensor Pumping Current Circuit / Open
• P2238 – Oxygen (A/F) Sensor Pumping Current Circuit Low
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-16-2009, 11:58 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
huh, hope this doesnt happen to mine.
Old 06-17-2009, 09:06 AM   #4
DerFlosser
DerFlosser's Avatar
Thank you for sharing this with the community. Scary indeed....
DerFlosser is offline   Reply With Quote
Old 06-20-2009, 12:56 PM   #5
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
Did anyone else get this in the mail?
SSC 90C - Certain 2006 through 2007 Yaris Vehicles Center Pillar Insulator Saftey Recall Notice
Long story short if you get in an accident your seatbelts may not lock!
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 06-20-2009, 01:25 PM   #6
supmet
Drives: 2007 4 Door Yaris
Actually, there is an extremely minute chance of the pillar insulation foam catching fire from the seatbelt pretensioner. So far only 1 or 2 yaris have caught fire from this, but the seat belts work fine. Also, there are already a million threads on this.
Old 06-26-2009, 09:17 PM   #7
auxmike
auxmike's Avatar
The whole DBW thing does'nt thrill me.
I rather have a real throttle cable anyday......
Old 06-26-2009, 09:20 PM   #8
AlexNet0
AlexNet0's Avatar
how does this apply to this thread...? haha
And about the pillar recall, you can do that yourself if you dont wanna take it in, there is a DIY floating here somewhere I think I saw.
Old 06-26-2009, 09:28 PM   #9
auxmike
auxmike's Avatar
That harness has the wires that operate the electronic throttle body, thus Drive By Wire (DBW).
See??
Old 06-26-2009, 09:32 PM   #10
AlexNet0
AlexNet0's Avatar
See??
haha im sorry, that went right over my head, now I feel like an idiot.
Old 06-26-2009, 09:42 PM   #11
auxmike
auxmike's Avatar
Just kidding......
Old 06-27-2009, 07:28 AM   #12
CB900F2
Drives: 08 Sedan
Hey guys.. Does anyone have a copy of the TSB they can post?
CB900F2 is offline   Reply With Quote
Old 07-20-2009, 08:44 AM   #13
cab
Drives: Yaris 2007 Sedan
Hi Guys,
I own a Toyota Yaris 2007 Sedan (very nice condition...I though) with 48k miles.* "check engine" light goes on and off, and the engine suddently shuts down at least twice everytime I drive it.* I was told by a certfified dealer that I have to replace the wiring harness because quite a few codes (including P0102) are being reported by the car but the dealer, the "bumper to bumper" warranty company, and Toyota refuse to take any responsability.* I have seen at least two similar cases reported in this forum.* I am considering taking legal action.* Any suggestions?*
cab is offline   Reply With Quote
Old 07-20-2009, 09:51 AM   #14
PatrickJohnson
Drives: 2008 Yaris LB
tell them you know it is a known defect and provide them with the TSB number:
TSB #0344-08
Then see how they react.
PatrickJohnson is offline   Reply With Quote
Old 04-21-2010, 05:29 PM   #15
clint3142
Drives: 2008 Yaris Manual Trans Sedan
TSB-0344-08
TSB copy
clint3142 is offline   Reply With Quote
Old 07-12-2013, 06:12 PM   #16
jintermeister
Drives: 2008 Yaris
Any other luck with this?
Hey all, I stumbled upon this thread due to similar problems with a Yaris I just bought used (private party), hatchback ~55k miles. Issue is low coolant signal, error code P0125, and I looked at the TSB and I fit the bill exactly (VIN number within range, error code solo, etc.)
Otherwise loving the Yaris, but this issue bugs me. Seems like some have had luck getting it replaced no charge, and others not. Any more success stories? Any idea of what is actually wrong with the harness? Maybe it's just a bad connector or something that can be fixed yourself?
CAB, did you have any luck when you told them about the TSB?
Calling around to the dealers to see what they say. I find it strange this is not really a recall?
Luckily my car is not shutting down or anything (right now), but makes me question the validity of the over-temp light as well. Calls into question a number of engine related stuff.
jintermeister is offline   Reply With Quote
Old 03-26-2015, 11:58 PM   #17
ramiyaris
Drives: 2008 toyota yaris dark blue
p0125, not sure what else to do.
Hey guys. I've had a 2008 Yaris brand new for seven years and have had no issues until recently. I've had the low engine temp light come on and the engine sounds like it's reving up after the car has been on for 30 minutes or longer. I've had the Mast air flow sensor changed, the water temp sensor changed(twice) and the Thermostat changed (twice as well). I've taken my car for a recall, nothing to do with the current issue, I informed the dealer they checked it out and said I needed a new water temp sensor so I bought it right from them and had it installed elsewhere(second time installed). I really don't understand the car lingo but what I'm getting is that I may have to change the engine wire harness? and that sounds expensive. A little explanation would be appreciated when possible. Thanks.
ramiyaris is offline   Reply With Quote
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 06:20 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 12:34 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
2007 yaris TSB tomjasz DIY / Maintenance / Service 5 09-20-2006 03:28 PM
