Old 06-18-2009, 11:55 AM   #1
regal
With TRD Springs do I need to adjust camber?
I had the car aligned after installing the TRD setup (Springs, shocks, sway bar) at the dealer, there were no crash bolts installed at the time. It seamed to alighn fine, but should I add crash bolts and have it realigned. Steering is very responsive almost to much, doesn't want to center itself.
Old 06-18-2009, 12:00 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
NO!!!!!
i wasnt screaming i just had coffee..lolz
Old 06-18-2009, 01:49 PM   #3
regal
caffein does that to me too, thanks
Old 06-18-2009, 02:47 PM   #4
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I'm adding camber bolts and having mine aligned once I put the TRD springs in. I'd like to dial in a little more negative camber than stock.
Old 06-18-2009, 04:51 PM   #5
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
You don't have to. It is just a matter of preference.
Old 06-18-2009, 09:12 PM   #6
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
You really only need to adjust your camber if your lowering quite a bit.
id3379 is offline   Reply With Quote
Old 06-18-2009, 09:51 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
SHoulding lowering a car add a slight negative camber already?
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
TRD Springs Shocks and Sway Bars IN STOCK Sparks Toyota-TRD Sparks Toyota 0 03-12-2009 09:54 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
TRD shocks with tein or trd springs? UKblackyari Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-20-2008 12:20 AM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
