Old 06-18-2009, 07:42 PM   #1
mastaofdisasta
mastaofdisasta's Avatar
Drives: yaris
bump stops?
I never cut my bump stops when i installed my df210s, is that a bad thing?
ballin on a budget.
mastaofdisasta is offline   Reply With Quote
Old 06-18-2009, 07:52 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
yes
Old 06-18-2009, 07:52 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
http://www.yarisworld.com/forums/sea...earchid=591061
Old 06-18-2009, 07:53 PM   #4
mastaofdisasta
Drives: yaris
link aint workin
ballin on a budget.
Old 06-18-2009, 07:54 PM   #5
mastaofdisasta
Drives: yaris
this was from an older post
I'm running the TRD (KYB) Sportivo absorbers with Springtech 1.8 inch lowering springs, I've had this recurring problem where at least once a week, I bottom out the front suspension on large bumps. And I mean I realllly bottom out the suspension, like @#%THUDDD!!!!#^%$. This cannot be good. The springs and absorbers feel great otherwise, just the big bumps and in fast bumpy turns is it bad.
When I installed my setup I cut the bump stops down as recommened by the spring company. This was also recommended in the Tanabe DIY by Chris07LB. The rear of the car doesn't have bump stops so no change there. I never bottom the rear.
So my bumps are currently about 1.5 inches long, maybe 2 inches. Having a bump stop that is half of or less than half of the original height can't be good. I understand that we don't want the stock bump stop limiting our suspension travel but we also want a bump stop that works and does what it is supposed to i.e., provide safety from bottoming while adding some progression at the end of the compression stroke of the main absorber. The bump stop is just an inactive miniature shock absorber and by cutting it, it's original qualities of absorbsion are lost. So I've been looking around for aftermarket replacements.
So I spoke to a a local autocross suspension tuner and he confirmed my "research" that cutting the bump stops is very bad in that it eliminates that final bit of progressive travel that the bump stop is meant to supply. He also confirmed that the bump stop is a crucial part of the suspension system. This is especially true in fast and heavy turns where a car will actually rest on the bump stop, not only preventing the suspension from fully bottoming but actually adding a very fine level of absorbsion for smaller bumps within the turn.
At this point, I have no final bit of progressive travel. It is gone. I go from suspension working good to... THUD. Supposedly, you can get back about an inch to an inch and a half of travel using these aftermarket bump stops. I already supplied this local tuner with my absorber info and he is going to try to get something together for the Yaris.
Let me know if anyone is interested. The price has not been specified but should be around $50 for a set of four. The price will be halved if you only want the front. I'll try to get him on here to answer questions once the kit is available.
I would also like to ask if any of you have used any of the aftermarket Koni bumps or if your suspension kit might have come with bumps? If you did a self install of the TRD Sportivo kit WITH SPRINGS, did the kit include instructions about the bump stop? I would think Toyota would speak to this in their instructions since the bump stop is an active part of the suspension, not just a stopper to prevent the absorber from banging into the shock hat.
Feedback?
Galavoxx is offline Report Post Reply With Quote
ballin on a budget.
Old 06-18-2009, 07:55 PM   #6
mrbond
mrbond's Avatar
It is a bad thing. I didn't cut my bumpstops when I first installed my DFs, but after reading around a bit, I promptly removed the struts and cut the bumps. Do it, unless you plan on replacing your shocks/struts soon with better ones.
- A Toyota Yaris
- A whut Yaris?
Old 06-18-2009, 07:56 PM   #7
mrbond
mrbond's Avatar
you mean kinda like the pre-formed bumpstops fatcat sells?
- A Toyota Yaris
- A whut Yaris?
Old 06-18-2009, 07:59 PM   #8
mastaofdisasta
Drives: yaris
so is it going to like destory the lifespan of my shocks?
ballin on a budget.
Old 06-18-2009, 08:05 PM   #9
mrbond
mrbond's Avatar
^ oh yes it will. Go and do it like Saturday morning. Doesn't take too long, and it is kinda important.
- A Toyota Yaris
- A whut Yaris?
Old 06-18-2009, 11:14 PM   #10
detroiter
detroiter's Avatar
Are you sure your not mistaking "bottoming out" the bumpstops for just having a stiffer jolt when you hit a bump? The upgraded shocks and springs will definately make bigger bumps alot stiffer then a soft wallowing type of asborbing motion.
Old 06-19-2009, 02:18 PM   #11
Nagoya_TRD.
Drives: None.
Cut the bumpstops about 25 to 30 percent of stock.
Just call or check with Tanabe i am sure they can let you know.
Nagoya_TRD. is offline   Reply With Quote
Old 06-19-2009, 03:00 PM   #12
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
out of curiosity, does the dealership do this when they install trd's?
Old 06-20-2009, 03:22 AM   #13
dallas
Drives: Yaris Hatch /Landrover D2
If you cut the bump stops you get that much extra suspension travel before the bump stop starts compressing, and acting like another spring. What you don't want is the car riding on the bump stops as it will not allow the suspension to perform properly. As long as there is enough bump stop compression allowed before the strut rod bottoms out your o.k. I think someone has tested this and cutting is o.k if I remenber right.
dallas is offline   Reply With Quote
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 04:49 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Bump Stops (going back to stock) texkid Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-11-2008 01:58 AM
TRD Sportivo with Tanabe NF210's and cut bump stops? Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 07-16-2007 08:21 AM
bump stops Jerkratt DIY / Maintenance / Service 4 06-24-2007 12:36 AM
