#1 |
depo hid retrofit w/high beam?
I tried to search this out but could not find anything short of a custom harness. I have the depo projectors(unfortunately) and I was going to install HID in the low beams but in this state I have yearly inspections so I need to have functioning high beams. I don't plan on needing them but they have to work and I don't want to buy a second set of HIDS I'd just like to hook up the halogens that come with the lights. Has anyone done this?
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
they are separated light bulbs. so it wouldn't affect anything if you just changed the low beams and keep the highs.
#3 |
That's what I was going to do, but I didn't know if I could just connect the high beams into the HID harness so that they would work. If I didn't have a damned state inspection every year I wouldn't worry about it.
#4 |
why would you want to plug the high beam harness into the HID ?? plug the lowbeam to the HID and plug high beam to the high beam halogen bulb ?
#5 |
OK, lets try this again. The depo lights take H1 bulbs, most HID H1 kits are set up that you lose the halogen high beam, I can't have that with my state inspection. As far as I know short of a custom harness you can't just plug it in, that's what I'm trying to see if anyone has found a way around it. or if a bi-xenon kit will fit but I really didn't want to go that route.
| HID - Even beam pattern????? | fuji | Cosmetic Modifications (Exterior/Interior) | 8 | 05-30-2009 07:34 AM |
| depo projectors with hid??? | ae92trueno7 | Cosmetic Modifications (Exterior/Interior) | 7 | 02-04-2009 11:15 AM |
| Which HID to get: Bi-Xenon or Hi/Lo Beam? | RSboyz | Cosmetic Modifications (Exterior/Interior) | 18 | 01-18-2009 10:47 PM |
| Hi & Lo Beam HID Conversion Kit | OgDogg | Items for Sale by private party | 0 | 11-11-2008 04:55 PM |
