Old 06-23-2009, 04:34 PM   #1
vicvs
Drives: toyota yaris (2 dr)
My A/C is not working> and summer just started help!!!!
well i recently bough an 08 yaris(2 dr) and starting to love it more and more everyfday........but...... for the last week my a/c has been blowing hot!!! and its like 100 degrees outside!!! i put in a can of r-134 and nothing. any one got any ideas?
thanks guys
im new to this forum too
so rock on
vicvs is offline   Reply With Quote
Old 06-23-2009, 04:37 PM   #2
did you buy private or dealer?
Old 06-23-2009, 05:32 PM   #3
vicvs
i bought it from a dealer
and i will check the fuses i didnt know how i could miss that
Old 06-23-2009, 05:32 PM   #4
Take it back to the dealer and have them inspect it.
Old 06-23-2009, 05:33 PM   #5
Also, too much freon can make it stop working as well. If the fuses are fine, and you don't want to go back to the dealership, bleed out all the freon and put back the correct amount.
Old 06-23-2009, 05:38 PM   #6
vicvs
sweet.... good info .... i dunno why i said dealer.
it was an aution
sorry
Old 06-23-2009, 05:44 PM   #7
Henry G.
Drives: 2008 Yaris HB
I believe almost all cars have a pressure switch that stops the compressor from running if the freon is low, this is to stop the compressor from burning up upon freon loss/low pressure.
Start the car and have someone toggle the AC on and off, you should see and hear the compressor starting and stopping. During normal use it should alternate off/on as needed to keep the AC cool, but when you first turn it on it should immediatley start. Also, on my Yaris the radiator fans come on as well, yours should too. It could be a simple as finding the pressure switch connection and wriggling or cleaning it, that has happened to me before on several other cars, either that or the switch needs cleaning or replacing, either way this is the first thing to check, especially if it was blowing cold before and then suddenly stopped. If it starting blowing less cool and then eventually stopped that would be more indicative of freon leaking.
Henry G. is offline   Reply With Quote
Old 06-23-2009, 05:54 PM   #8
vicvs
thanks guys ill try all of these before i pay someone to inspect it
Old 06-23-2009, 10:14 PM   #9
Did the AC work initially, and then it recently stopped blowing cold air, or did you discover it blowing hot air the first time you tried the AC?
Does the AC indicator LED light when you press the button?
Old 06-24-2009, 01:42 PM   #10
vicvs
hey... now that im thinking about it ... it did blow a lil cold but not as cold as i wanted so i put more freon... i think i put to much it there.
Old 06-24-2009, 01:46 PM   #11
silver_echo
ekodrvr
silver_echo's Avatar
just bite the bullet and have a tech fix it... i don't know about your area, but try to check if there is a training environment in your area... they might be able to fix it for MUCH less than any other shop would... there may even be a toyota t-ten program in your area...
the reason i bring that up is because i am in the t-ten program in my area...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-24-2009, 02:11 PM   #12
That would make sense. The Yaris AC system does have a pressure sensor, which is used to detect high (>455 PSI) or low (<28 PSI) pressure on the high pressure side of the system.
I have a recharge kit that has a gauge on it, which is really the only safe way to recharge one yourself. The recharge kit with the gauge was only about $10 more than one without.
The correct charge for the Yaris (measured on the low pressure side, where you charge it) is 0.15 to 0.25 MPa, which equals 22 to 36 PSI.
Old 06-24-2009, 02:36 PM   #13
silver_echo
ekodrvr
i would hope that that psi range is when the a/c is operating... not a static pressure...
Old 06-24-2009, 02:42 PM   #14
Correct (and good point). Automotive AC is always checked/charged with the engine running, transmission in neutral, and AC on.
Old 06-24-2009, 02:44 PM   #15
silver_echo
ekodrvr
<------------ currently in the toyota t-ten training program if that makes more sense...
Old 06-24-2009, 03:10 PM   #16
Cool. Which program are you doing (one year, two year, associates, etc.)?
Old 06-24-2009, 03:14 PM   #17
silver_echo
ekodrvr
two year... starting brakes/susp next week for summer quarter...
Old 06-24-2009, 03:18 PM   #18
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
if its under warranty WHY would you go and try to add freon to system? hopefully you get a tech who won't realize that you f'd with the a/c.....
Official Mid-Atlantic Summer 2009 Meet whooppee777 NY / NJ/ CT / PA 9 05-18-2009 12:07 PM
