Old 06-24-2009, 10:32 AM   #1
Lawrence Berk
Drives: 2007 Yaris LE
Question Automatic Transmission issues??
Hello all!
I have a question in regards to my automatic 2007 hatchback. I've noticed that when I start up the car, it seems that it needs time to warm up in order to switch gears properly. The revs will be slightly high when it gets up to 40km/hr until its been running for a couple of minutes. This happened in the cold Canadian winter, but is also continuing to happen through the summer. If I let the car idle for a couple of minutes before driving it doesn't seem to have this problem. Is this normal or is something up with my transmission?
I just purchased this car in November '08 at 50,000 kms. It's now at 68,000km.
Thanks!
Lawrence Berk is offline   Reply With Quote
Old 06-24-2009, 10:34 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Lawrence Berk View Post
Hello all!
Thanks!
have you yet serviced the transmission? new fluid?
Old 06-24-2009, 10:36 AM   #3
Astroman
Modded Moderator
Astroman's Avatar
It's perfectly normal for the automatic. Has something to do with warming up the catalytic converter for emissions. The warmer the weather, the shorter it takes to warm it up.
Old 06-24-2009, 10:54 AM   #4
Lawrence Berk
Thanks to you both!
Tamago, I have not yet replaced the transmission fluid. I'm a bit torn with that. I have heard various things, from not touching it until you are at 100,000 kms to replacing every 30,000 miles??? Not sure what to do. Please forgive my ignorance!
My oil, however, is changed regularly.
Old 06-24-2009, 11:43 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes, perfectly normal. Allow it to warm up for a bit or just drive it gently for a minute or so until it shifts efficiently.
As far as changing transmission fluid, check your Toyota owner's manual and follow those recommendations.
Old 06-24-2009, 12:16 PM   #6
BLH
Drives: 2007 Yaris Sedan
My 2007 is exactly the same. Normal Operation.
As long as the Cold Icon is on. It will not shift the same as when warm. In fact mine even has to be warmer than the 130 degrees my Sacanguage reads when the Cold Icon goes off.
Old 06-24-2009, 01:18 PM   #7
Darb
Bear Traffic Controller
Darb's Avatar
Same here as well.
Darryl
Old 06-24-2009, 04:41 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
When I pull out on the highway and accelerate to 55 MPH while the "COOL" light is on, it takes another 10 seconds or so after the light goes out before it'll shift into high gear. While the engine's cool, it's also got the intake cam timing fully retarded, the EGR and O2 sensor feedback loop are disabled, and the spark timing's retarded. Warms everything up faster that way.
Old 06-25-2009, 10:28 AM   #9
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
This is normal, in general I experience the higher RPM shifting until a few moments after the cool coolant light goes off. In the summer its usually the first minute of driving if vehicle is engine is cold, in winter it may be 2 or 3 minutes. as I don't normally hit 40 to 50 mph roads until about a mile from home. and its never been a problem. But completely part of the design of the computer.
198K Miles
N9QGS is offline   Reply With Quote
Old 07-02-2009, 01:12 PM   #10
Christopher
Cobra
Drives: '07 3-door
Its normal. This is how the engine gets to operating temperature quicker.
Christopher is offline   Reply With Quote
automatic, high revs, transmission
Automatic Transmission Question daf62757 New YARIS Purchase Forum 16 02-16-2009 10:41 PM
NST Pulleys + Automatic Transmission WeeYari Performance Modifications 17 01-31-2009 12:29 PM
How to check automatic gear transmission oil iaq DIY / Maintenance / Service 4 12-04-2008 01:50 PM
Will thicker automatic transmission oil help with pick-up ? nurburgring General Yaris / Vitz Discussion 3 08-01-2007 04:15 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
