Old 06-26-2009, 12:14 PM   #1
nimith
Drives: 2007 yaris hatch
TSB 0344 update from 6-20-09
Toyota replaced my wire harness and then they replaced my throttle body all at no charge. I have 45,000 miles on my 2007 hatch. If any of you are having
trouble with the above and are out of warranty, make sure you tell dealer that Toyota knows of this problem and should make you whole!!!!!!!
nimith is offline   Reply With Quote
Old 06-26-2009, 01:05 PM   #2
what exactly was the issue?
Old 06-26-2009, 02:22 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Could you post the TSB?
Old 06-26-2009, 02:26 PM   #4
auxmike
auxmike's Avatar
Please be specific.
Old 06-26-2009, 02:30 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
found it but cannot post for some reason.
Old 06-26-2009, 04:13 PM   #6
nimith
The issue was the car kept stalling (the gas pedal was just dead) I was getting a code that said trouble with the throttle position sensor but Toyota said replace the wire harness. After replacing the wire harness still had same problem so they then replaced the whole throttle body. Three days now with no problem. I told them to peplace throttle body from the start, but they first did the wire harness.
Old 06-26-2009, 04:15 PM   #7
nimith
You can also read my post on 6-20-09
Rattle TSB I found the other day. ToyotaTEch21 DIY / Maintenance / Service 37 05-29-2018 11:17 AM
Dash rattle TSB needed ! tsportman DIY / Maintenance / Service 15 07-06-2009 06:20 PM
TSB for flaws. hans_fh General Yaris / Vitz Discussion 3 08-01-2007 09:38 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 12:34 PM
