Old 06-26-2009, 03:51 PM   #1
mrbond
mrbond's Avatar
Header from Thailand
I saw this the other day and I was pretty amused. There's no O2 sensor hole, nor is there a mounting hole for the bracket that keeps the manifold securely anchored to the engine block. But still a novel idea...for about $90 USD.
http://www.rstyleracing.com/index.as...80206215336521
- A Toyota Yaris
- A whut Yaris?
Old 06-26-2009, 03:54 PM   #2
likey for a previous gen yaris....aka echo hatch....pwnt
Old 06-27-2009, 07:06 AM   #3
oon_resist
oon_resist's Avatar
Drives: Yaris TRD Sportivo
oon_resist is offline   Reply With Quote
Old 06-27-2009, 10:07 AM   #4
mrbond
mrbond's Avatar
^ where is that thing sold? It's still missing the support bracket, and the O2 hole is on the opposite side, but it's still quite an interesting looking piece.
- A Toyota Yaris
- A whut Yaris?
Old 06-27-2009, 10:52 AM   #5
Bracket is for the heat shield which is not absolutely necessary... as for the sensor hole, it does not need to be in the exact same location as long as it's in reach of the wiring...
Old 06-27-2009, 11:02 AM   #6
mrbond
mrbond's Avatar
No no, not the bracket for the heat shield. There's another bracket that anchors the manifold to the engine block, to keep the manifold from moving around and risking breaking and so forth. Like, on the Megan and DC headers, there's a small slab of metal at a 90 degree angle on the collector flange.
As for the sensor hole location, I don't know if the sensor would be able to reach all the way to the other side. As it is, it was being stretched a little with the Megan.
- A Toyota Yaris
- A whut Yaris?
Old 06-27-2009, 01:10 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
that looks like it is for the xb, xa and echo
Old 06-28-2009, 09:39 PM   #8
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
most of the after market headers dont have a bracket, i dont have one for my MR2 as well
seems like you dont need one
http://www.4055design.com
Old 06-28-2009, 10:46 PM   #9
What bracket do you mean? All the headers I've seen are attached to the head by the flange and nothing else.
The collector flange is nowhere near the head?
MEGAN RACING
THUNDER STREET
Old 06-29-2009, 07:04 AM   #10
^ my thoughts exactly...
Old 06-29-2009, 09:10 AM   #11
mrbond
mrbond's Avatar
I'd put up a picture with a circle made around this bracket, but my work's proxy won't allow me to upload pictures. See, the Megan header has it, but the Thunder doesn't. It's the bracket ON the collector flange, mounted perpendicular to it. I suppose, though, that it's not a necessary thing.
- A Toyota Yaris
- A whut Yaris?
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
