Old 06-29-2009, 04:04 PM   #1
jonismyname
Drives: 08 liftback 5spd
konig 17x7 v-racing, worth the work?
was just handed a free to me set of 4 konig v-racing 17x7 wheels, 40mm offset, 4x100... with a junk set of tires. i like the look and layout, but the bad is:
a few small bends. one maybe an inch of the bead is flared out, the other a small bend on the outside of the same form. 3 tires still have pressure from a year ago, the one with the bent bead has lost air. im comfortable smacking the bead back in place. i am familiar with aluminum and am not worried about it.
the surface of 2 wheels is good enough, these have a polished lip that is rather coroded, 15 mins with a scotch-brite didn't do what i hoped it would.
anyone had good results resurfacing alum wheels? i was thinking bead blasting, painting, and clear-coating, then hoping for a good deal on tires?
15lbs seems reasonable for 17" wheels... am i going to regret this performance wise? 205/40/17 is what the previous owner used on a saturn, the sizing seems approriate for the yaris? or are 45 series more correct?
im open to opinions, many say not to bend aluminum wheels, but for free, i'll smack it with a hammer and a chunck of wood... it's not load bearing, and i don't expect to remove a chunk of the wheel doing this...
jonismyname is offline   Reply With Quote
Old 06-29-2009, 04:09 PM   #2
supmet
Drives: 2007 4 Door Yaris
Are you sure they only weigh 15 lbs? I'd bet they are closer to 17 or 18(or more).
Old 06-29-2009, 04:19 PM   #3
jonismyname
stamped on the wheel is via 690kg
i assumed 690 is 6.9kg=15.22lbs.
i expect you're right, that was wishful thinking...
whats the 690kg then?
Old 06-29-2009, 04:26 PM   #4
jonismyname
http://www.konigwheels.com/images/243_s.jpg
thats what they used to look like.
Old 06-29-2009, 10:24 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
690 kg is the max weight they can support per corner...
they are probabbly close to 20lbs each
Old 06-29-2009, 10:48 PM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
20lbs! yikes
Old 06-29-2009, 10:58 PM   #7
690 is... well, 690. x 2.2 = 1518 pounds. Castrex is correct on this one, I think.
Old 06-30-2009, 01:09 AM   #8
Imo, fixing the rims will cost about the same, if not more than a new set.
Old 06-30-2009, 08:22 AM   #9
jonismyname
well i was afraid of that. the car is pokey as it is. cost would be considerably less than buying new... i work in automotive industry and have access to a bead blaster, and a powdercoat oven, and employee priced wheel paint rattle cans. the weight is the only thing that scares me, unfortunately i guess i'll "go fish". thanks guys!
Old 06-30-2009, 12:13 PM   #10
baked_limabeans
Drives: Polar White
16x7 v-racing are 18 lbs
so the 17s will be heavier
baked_limabeans is offline   Reply With Quote
Old 06-30-2009, 12:50 PM   #11
33OH
Drives: '08 Yaris
I'd say try to sell them on Craigslist for $100 OBO and see what happens.
I wouldn't have them fixed or put them on a Yaris, those are some heavy wheels.
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 07:43 PM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
