#1 |
Double-DIN DVD Touch Screen AVH-Pioneer P4100DVD
Hello everyone!
I wanted some opinions on this stereo that I'm looking at getting for my 09 Yaris Sedan. http://www.pioneerelectronics.com/PU...s/AVH-P4100DVD Does anyone have this model installed already? Any better suggestions then this unit? I've found this model for about $400 and it will display album art and play videos from your iPod. I'd really like a stereo that let me rate songs but it's going to break the deal for this model. I'm not sure if this deck will do that but if anyone knows of a deck that will please advise. So far it looks like I'll need: Silver Toyota Dash Trim p/n 55405-52640 Metra 95-8202 (gap filler) Metra 70-1761 (Wire Harness) Do I need to get the Metra 99-8216?? Is that where I get the mounting brackets from? Does this kit work for Double-DIN installs as well? Also even though I selected aYaris Sedan from Metra's web site it says this mounting kit is ONLY for Hatchbacks. Seems weird to list it under a sedan, maybe it's a typo. Any help would be great, thank you in advance.
AVHP4100DVD
No one?
Here are some pics. |
#3 |
Your part list is correct. You don't need the 99-8216, just the 95-8202. You reuse the OEM radio's mounting brackets to mount the new HU.
#4 |
That looks great. Do they have the same model with navigation? If it's only $100 or so extra I would go for that.
#5 | |
DVD Options
![]() I could go with a AVIC-X710BT which has GPS but it's only a 5.8" screen and it's MSRP is $999.99 I'm not worried about GPS I'll either use my Android phone in my ProClips mount or get a separate GPS unit. |
#6 | |
#7 |
#8 | |
Silver Toyota Dash Trim p/n 55405-52640 Metra Gap Filler 95-8202 I thought that I would need a Toyota to Pioneer wiring adapter so that I don't have to splice up the Toyota plug into the Pioneer. Any ideas on what that part number might be and if I need it? Are there any other parts that you guys can think of that I'll need? Thanks for the help. |
#9 |
Vitz!
I used the same Metra kit to install my double-din radio. I also went to crappy tire (Canadian Tire, pep-boys or something similar in the US will probably carry them) and got the Toyota wiring harness kit and soldered it together with the Pioneer one.
Pic of the stereo installed (this is an '05 Echo hatch):
2005 Toyota Echo CE Hatch -- GTSpec strut tower brace & front chassis under brace, Tanabe rear under brace, Progress 22mm rear anti-sway bar, Energy Suspension front poly anti-sway bar bushings, 16x7 MB Boost wheels, 205/40R16 Toyo Proxes 4, JDM power mirrors, Tein SuperStreet coilovers w/pillowball mounts, TRD Quickshifter (using stock weighted shift knob) -- |
#10 |
Yaris to Pioneer Wiring Kit
Any chance you know what the part number is for that wiring kit?
#11 |
Metra 70-1761
#12 |
I'd also like to do this.
AVH-P4100DVD Bypass I think I'll also need a Auto Zone #19273 Duralast Relay or a similar relay in order to bypass the safety features for full iPod control while I'm driving. |
#13 |
#14 | |
I started watching the video and was thinking why the heck isn't he just grounding the ebrake wire. Then, at the very end he mentions the need for that HU to see the ebrake input toggle, instead of just being permanently grounded. |
#15 |
![]() ![]() Drives: Yaris hatchback Join Date: May 2007
mine is a P4150 but i think the model is diferent because i'm in central america by the way anybody have any idea on how to hide this screen
#16 |
I'd like the get the S version of the Toyota Dash Trim. The silver version is 55405-52640.
#17 |
Nice Trim!
I'd like to get rid of all the ugly silver trim pieces and have my interior look like this. I'm hoping that the S version sedans come with black trim like the VIOS.
#18 | |
Panel Sub-Assy, Instrument Cluster Finish, Center
Since you have access to the catalog are there any black versions of the silver panels? What model do they come with stock? I've listed the part number for the silver version that you had given out before. Panel Sub-Assy, Instrument Cluster Finish, Center, Silver It's part number is: 55405-52790 |
| Tags |
| double-din, p4100dvd, pioneer, stereo, touch screen |
