Old 06-30-2009, 01:13 PM   #1
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
engine swap !
Originally Posted by xnamerxx
you nailed it sir.
Old 06-30-2009, 01:15 PM   #2
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by wiki
In 1998 a second version was released with dual VVT-i (variable timing on both the intake and exhaust cams), titanium valves, battery-backed injectors and a slightly higher compression ratio (11:1 instead of 10.5:1). This engine powered the Altezza RS200 and produced around 207 bhp (154 kW, 210 PS) @ 7600 rpm.
wiki rocks!
you nailed it sir.
Old 06-30-2009, 01:44 PM   #3
90tsi
90tsi's Avatar
Drives: 09 yaris
how big is this motor..? im gonna assume its a 2.0. will out trannys bolt of the back of it?
90tsi is offline   Reply With Quote
Old 06-30-2009, 01:44 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
and this would fit how in a yaris? unless you get rid of the tranny
the same way an RWD fit in NST's yaris
you nailed it sir.
Old 06-30-2009, 04:47 PM   #5
when did NST get a RWD Yaris built, did I miss something?
Old 06-30-2009, 04:52 PM   #6
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
ooh Beams engine. I am planning on going with a silvertop closer to the warranty expiring.
Old 06-30-2009, 05:26 PM   #7
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
nice if you want to brag but far better engines out there for the money
i speak from first hand experience
http://www.4055design.com
Old 06-30-2009, 05:48 PM   #8
another engine swap thread!
Old 06-30-2009, 05:49 PM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
RWD > FWD
you nailed it sir.
Old 06-30-2009, 05:49 PM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
2.0 yes, and no, don't separate it from this transmission lol
you nailed it sir.
Old 06-30-2009, 06:00 PM   #11
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
IN the xA or a Yaris?
Old 06-30-2009, 06:44 PM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
either. the yaris has more room because of your non-hydraulic steering rack :)
you nailed it sir.
Old 06-30-2009, 11:27 PM   #13
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
kustomplay: is that engine in an MK1 MR2?
Old 07-01-2009, 01:10 AM   #14
kustom play
Drives: 07 liftback
na its in a MKII
they use the silver top for the MKI
and the black top for the is300
i always wanted to get a BEAMS motor so bad, when i first got my MR2 it was the only way i was going to go, then one of the guys here swapped a beams into his MR2 and it was so sad, its nothing like expected power wise. it was a bigger kick but nothing compared to the capabilities of a turbo or V6.
i know when i found one it was 5K for the engine alone, it didnt include the ECU nor the gauge cluster, i could only imagine what they go for now.
its cool if you want a super rare swap to show but producing power your money could be spent on better setups
if I had 2 cars, i would pick up a BEAMS for bragging rights in a heart beat!
Old 08-11-2009, 05:38 PM   #15
midengine3sgte
Drives: 85 corolla, 06 tacoma, 07 fj
I've always like the beams 3S for NA swaps
midengine3sgte is offline   Reply With Quote
engine swap complete! Adriaan Canada 3 03-05-2009 11:50 PM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
Need help badly looking for engine swap places in gta Adriaan Canada 7 02-23-2009 09:14 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 02:40 PM
