Old 07-04-2009, 06:52 PM   #1
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
What did I do???
I just cut a 2" hole into the top left corner of my bumper to allow more air into my AFE cold air intake area. I put 1 1/2" threaded PVC fitting into the hole to "finish" the look for now.
Well, I'm getting a "check engine light" now. Did I screw up the engine or is the MAF sensing more air and feeling the car is runnig lean, or is it possible air might be flowing back through the hole.
I have an AX in the morning and am panicked...
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
