Old 07-06-2009, 04:16 PM   #1
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Micron 4?
I have a Micron 4 used for a single cylinder racing kart. Is ther any way to use it as a Tac on the Yais?
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 07-06-2009, 05:15 PM   #2
Did you contact the manufacturer?
Old 07-06-2009, 05:31 PM   #3
Lazerdot
Lazerdot's Avatar
Not Yet.
Info on YW seems to be the quickest and folks have real experience. Hows your underpanel working out?
Money is tight right now but between you and Mike, once I get some it will be gone quick!!
By the way, a reset of the ECU took care of the CEL I called you about.
AX went well this weekend, still need some stickers to show off Micro Image..., white or blazing blue...
