Old 07-06-2009, 07:23 PM   #1
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Blackend inside exhaust tip
I was washing my car and noticed black stuff inside the exhaust pipe and outside on the bottom part, is this a problem or not? Picture of black stuff below hopefully you can tell.
Cutie Pie #2 is offline   Reply With Quote
Old 07-06-2009, 07:26 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
normal. its just carbon buildup. wash it up real good and then it will be gone! until next time...muhahaha
Old 07-06-2009, 07:51 PM   #3
Cutie Pie #2
Thanks guys, just needed to be sure.
Old 07-06-2009, 11:07 PM   #4
Penguin Garage
Penguin Garage's Avatar
depending on your driving habits, people following you may see a puff of "smoke" come out of your exhaust, which is actually just that buildup making its way into our lovely green earth :D . but if you drive balls (errr... ovaries...??) to the wall all the time the buildup never.. builds.. up... in your exhaust :D
Penguin Garage is offline   Reply With Quote
Old 07-06-2009, 11:16 PM   #5
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
im almost ashamed to own a yaris after reading this
Old 07-06-2009, 11:21 PM   #6
mikenacarato
SIPNDEW
Drives: 15 STI
why?
Old 07-06-2009, 11:22 PM   #7
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
don't worry, we're all ashamed you own a Yaris too
Originally Posted by xnamerxx
you nailed it sir.
Old 07-07-2009, 12:16 AM   #8
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
Carbon, the time to worry is if it starts to turn light gray
Bob Dog is offline   Reply With Quote
Old 07-07-2009, 01:04 AM   #9
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Mine stays shiny and clean inside under normal circumstances. If I punch the gas pedal all the way down and hold it for a while, as I've occasionally done on a long uphill merge ramp onto the Interstate nearby with 4 adults in the car, the exhaust tip turns black inside. Get beyond about 80% load, and the engine goes into open loop operation with the mixture enriched. You'd likely see some smoke from the tailpipe under those conditions. Wipe out the inside of the tip with a damp paper towel, and see how long it takes to blacken again. Pay attention to how you're driving when it does.
Old 07-07-2009, 09:30 PM   #10
TheSilkySmooth
TheSilkySmooth's Avatar
But, How come most Fords have clean tail pipes?
Old 07-08-2009, 08:46 AM   #11
Yaris Hilton
Smile
Maybe their owners wipe better?
Old 07-08-2009, 03:37 PM   #12
silver_echo
ekodrvr
silver_echo's Avatar
because the Found On Road Dead does not run long enough for carbon buildup...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 07-08-2009, 08:02 PM   #13
BLAZINBLUEVITZ
Originally Posted by mikenacarato View Post
why?
pretty pathetic isn't it. its a good thing im getting rid of it
Old 07-11-2009, 05:54 PM   #14
areithan1980
areithan1980's Avatar
Drives: 2007 Yaris Hatchback
LMAO!
LMAO!!!!
areithan1980 is offline   Reply With Quote
Old 07-11-2009, 05:56 PM   #15
areithan1980
ROFL!!!!!!!!!!!!!
lololololololololololol!!!!!!
Old 07-11-2009, 10:23 PM   #16
06silveryaris
Drives: 2006 yaris
The get driven on a flatbed which probably has carbon on its tailpipe
06silveryaris is offline   Reply With Quote
OEM Exhaust Tip Accessory Split Cosmetic Modifications (Exterior/Interior) 36 07-12-2009 09:48 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
exhaust tip DJ_stone Cosmetic Modifications (Exterior/Interior) 1 01-20-2009 08:52 PM
Exhaust Tip Decision ruimond Performance Modifications 19 12-15-2008 01:49 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
